Hi Mav,
Thanks for responding - I need the help!
I've already confirmed that Planning isn't required - even if I wanted to change the garage door, it falls under "permitted development" (which is a miracle, given all the restrictions in the deeds - apparently, I'm not allowed to keep alligators or crocodiles as pets!
Originally Posted by mavice
From their words in the letter, why do you think they want you to build a masonary wall ? The double wall mentioned could just as easily be a stud wall with membrane outer, and insulation (and I would recommend soundproofing) and then the inside boarded with plasterboard - maybe 2 layers of plasterboard to afford more soundproofing.
Ah - that makes more sense! I was assuming that they meant a double-leaf masonry (i.e. cavity) wall - which was begging the question "just how small would my cinema conversion end up?"
I take your point on the soundproofing, though - I had been planning to build the wall as follows:
1. membrane
2. 4x2 studwork @ 450mm centres
3. 50mm rigid insulation boards between joists
4. 2 layers of 12.5mm plasterboard
Lots of Googling and scribbling on the back of a fag packet reveals that _should_ have a U-value in the region of 0.2-0.3 (dependent upon the type of insulation boards used).
the wall will not be structural as there is obviously a lintel already over the door.
Yep, although this wall of mine is going perhaps 4-6" behind the garage door (I'm going to put a 12" 'flood barrier' of brick & concrete down right behindthe garage door to prevent any ingress of water from coming underneath - just in case!)
it might be as simple as a telephone call to building control to discuss your intentions
That's what got me into this mess in the first place - asking silly questions of a Duty Officer over the phone!
I guess I need to just pay attention to the regs for the various areas of consideration:
- thermal insulation (looks to be covered)
- sound insulation (2 of the 4 walls are internal, so don't matter; anyone have any ideas for soundproofing the exterior 2 walls?)
- heating (we're going underfloor electric heating mats - no radiators = maximum space for big comfy chairs!)
- ventilation (planning to fit 100x100mm inlet and extraction vents into the ceiling, with low-speed fans in the ceiling void in case it gets stuffy)
Anything I've missed?
Equipment to start with will be what I've already got lying around - Sony 1200ES receiver, HTPC as DVD player (MCE box with upscaling S-video input), Infocus SP4805 PJ, B&W P4 fronts, Mission centre and surrounds.
Hoping to come into some money this year
, in which case that lot will go into a bedroom in favour of a 3-chip DLP, Dali speakers (7.1) and something like an Onkyo 875 driving it!
But need to build the room first! Hopefully I'll send in the plans in the next couple of days, and be ready to start in a week or so - YAY!
Neil.
