Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Looking for wall and skirting board trunking for hiding cables TheBoingoBandit Custom Installations and Installers 13 05-02-2009 9:45 PM
Hiding cables on a wall mounted plasma? matrixsc Interconnects, Speaker Cables and Switches 5 31-12-2006 7:24 PM
Hiding cables behind skirting boards? mjn Home Cinema DIY 16 16-10-2006 10:26 AM
Hiding AV equipment behind wall mounted plasma! Gez_pw6 Custom Installations and Installers 5 10-03-2006 1:34 PM
hiding cables on wall mounted lcd johnjet Flat Screen TV Brackets and Mounts 3 01-02-2006 7:03 PM
Old 31-01-2008, 1:10 PM   #1 (permalink)
Thanks: Gave 6, Got 2
hiding wall mounted LCD Cables - Getting behind the skirting boards
hello all
Just a quick question after looking at mny great threads on these forums i've decided to have ago at mounting my telly and hiding the cables.
I've got as far as mounting the telly and a shelf for the center which however needs moving (too close to the telly)
here is a pic so far.
Anyway my question is, having never chased a wall out, when i get down to the skirting boards is there a way i can get the cables behind the skirting and under the floor boards without taking them off? and if not (as i suspect) what is the easiest way to go about this?
SunTzu is offline   Reply With Quote
Old 31-01-2008, 2:00 PM   #2 (permalink)
zanetti4's Avatar
Thanks: Gave 46, Got 22
Re: hiding wall mounted LCD Cables - Getting behind the skirting boards
Hi SunTzu
This depends - is your house a new build? Is that solid wall? Or is that a just plasterboard on a wooden frame?
If it is a solid wall - then yes you can use a wall chaser - I did - I hired one from jewsons - messy job (in terms of dust!)
Regarding the skirting - this is either glued on or is nailed on - either way there is usually a gap where the plasterboard finishes and the floor - cabling should fit in there no problem
As regards the floor boards are you chasing the wires to the other end of your room - if so the easiest thing maybe to route the cable wround the skirting to the other end of the room (provided there is no break in the route e.g. a door frame)
Best of luck - any other questions let me know
zanetti4 is online now   Reply With Quote
SunTzu (31-01-2008)
Old 31-01-2008, 4:33 PM   #3 (permalink)
hello zanetti4
the house was built circa 1910 so not a new build and the wall i believe is solid brick, however when i was drilling to mount the LCD bracket there seemed to be some kind of cavity an inch or 2 in. i must say my knowledge of building DIY is limited so i would be winging it.
i'm routing the cables to a chest of draws just to the right of the tv where i'm going to build some shelve for my kit
so i was thinking straight down from the tv under the floor boards and then bring the cables up from the back of the chest of draws
do you think there would be enough room to get a plug/skart lead behind the skirting because i believe it may have been screwed to the wall and i fear if i rip it off i'll never get it back on neatly again
Old 31-01-2008, 4:46 PM   #4 (permalink)
something like this
Hope you all like my paintshop skills
Old 31-01-2008, 4:47 PM   #5 (permalink)
Thanks: Gave 1, Got 9
One thing you could consider is to exit the cables next to your twin socket using one of these plates assuming your shelving will be near by.
peevo is offline   Reply With Quote
SunTzu (31-01-2008)
Old 31-01-2008, 4:53 PM   #6 (permalink)
Hello peevo
i was planning on moving the twin sockets to the right so theyed be hidden by the chest of draws and adding some more sockets for gear and bringing the cables up round the back of the draws so you wouldn't see them.
Allthough this is something else i'm a bit stumped by i have 9 items that need plugging would it be best to use multibars or is there a nother solution?
boards, cables, hiding, lcd, mounted, skirting, wall
