| Help! - Advice on my wall and plasma mount!
Hi Guys,
The lounge redevelopment is underway, and I hoped someone could advise me on my wall, which is the wall between our place and the neighbours house, as I'm a little confused! The house is about 25 years old.
Basically, I was channelling into the wall, and went through the following layers:
Top 3mm - I presume is finishing skim plaster - chipped off easily after I scored the edges of my channels.
Next 10mm approx - quite brittle, light grey-coloured material -plaster I presume?
Next 25-30mm approx - sandy coloured material, took a while to chip through, but scrapes off quite easily and creates quite a lot of sandy dust...
Anyway, I wasn't planning to go so deep, but I managed to make a small hole by accident, going through the sandy coloured material. I expanded the hole a little to check what was behind there, and if I put my screwdriver through the hole, there was an air gap of about 40mm, with a hard surface on the other side.
If it was breeze block, I would assume the air gap would be double what is there. I tried drilling some holes in a few other places too, and with a 50mm (in length) drill bit, and it passed through the layers as described above, and hit the air gap as expected.
The question is, what kind of walls do I have, and what will be the best way to fix my 42" plasma to the wall? I currently have 60mm concrete anchors, with 60mm fixing screws, both of which were supplied with the bracket.
Any advice would be great,
Thanks guys,
Matt
__________________ Matt McSpirit Pioneer PDP-LX 5090, Yamaha RX-V2700, SVS SBS-01 5.1 System, PS3, Xbox 360 Elite, Sky+, Denon DVD-1730, Bluejeans HDMI) |
