Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Wall mounting a 42" plasma on to a stud wall SimonH Home Cinema DIY 3 11-01-2008 5:39 PM
Plasma Wall Mount - suggestions for neatest install in new-build stud wall? Reg_the_Veg Flat Screen TV Brackets and Mounts 0 26-02-2007 10:34 PM
Mounting a plasma IN a stud wall damolong Flat Screen TV Brackets and Mounts 3 17-11-2005 3:45 PM
Fitting Plasma & speakers to stud wall?? SimonBut Home Cinema DIY 1 18-02-2005 12:22 PM
Plasma mounting on Stud Wall BoomBoom Flat Screen TV Brackets and Mounts 2 04-10-2004 9:31 AM
Old 25-01-2008, 8:38 AM   #1 (permalink)
Recessed Plasma in stud wall questions!!
I'm in the middle of a whole house extension/renovation project (I will get round to doing a thread on it like Al's) and at the weekend I am supposed to be building a stud wall to sink the plasma into. I do not have the plasma yet (can anyone recommend a top 42" Full HD screen then?) and I don't particularly want to buy it yet as I'm not living at the house and all the dirty work i.e plastering is still to be done. I do have the bracket as I want to resin bolt it to the wall then build the stud around it so that I have about a 2" gap around the screen and the screen flush with the front. I'm hoping to decide on the screen today so that will be simple to get the measurements I need BUT what I don't know is how will the bracket line up with the holes on the back so that I can get the screen dead centre? Is it a case that the screen has several holes for adjustment?
How deep have others recesses been?
Tony
TJP32 is offline   Reply With Quote
Old 25-01-2008, 8:58 AM   #2 (permalink)
Thanks: Gave 11, Got 62
Re: Recessed Plasma in stud wall questions!!
My plasma bracket has hooks that fix onto the back of the plasma and a rail which screws to the wall. I can the slide the plasma up and down the rail quite freely ( to a point) so I didn't need to overly worry about getting it dead centre. Obviously you'll need to worry about the vertical as well which you will need to get right.
My build
cybrey is offline   Reply With Quote
Old 25-01-2008, 9:04 AM   #3 (permalink)
I know the bracket has horizontal adjustment in the same way you describe but I can't see how I can get the vertical position right without actually having the TV hooked up to the bracket to take measurements?
Old 25-01-2008, 9:20 AM   #4 (permalink)
Thanks: Gave 603, Got 516
Hi Tony
the only way is to pick the screen you are having and whilst in the shop take measurements
or try looking on the net at the manufacturers figures and see if you can do it that way but the first is a better option
sounds like your well on the way mate so we need pics quick
Allan
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
plasma, questions, recessed, stud, wall
