Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Extending Analogue cable from one room to another? Dfects Interconnects, Speaker Cables and Switches 0 14-11-2007 5:26 PM
Dedicated room or Front room? CrispyXUK Home Cinema DIY 23 17-01-2007 3:43 PM
Extending SKY HD Cables to other end of room markmm Sky HD 1 01-12-2006 11:29 AM
Extending multi-room Sky ectoplasm Sky and Sky+ 11 13-01-2006 2:23 PM
my front room leon Home Cinema DIY 46 15-08-2004 6:20 PM
Old 23-01-2008, 12:55 PM   #1 (permalink)
Rob_Meister's Avatar
Thanks: Gave 77, Got 37
Extending IR to front of room
Hi all,
I am after a decent and inexpensive method of extending my amp, Sky HD and media centre PC's IR to receieve signal from the front of the room, when they are positioned at the back.
Any help appreciated.
Rob.. PSN: RobMeister88 | XBL: RobMeister87
Bedroom Setup: Optoma HD70 | Pioneer VSX-AX2AS | PS3 | Xbox Elite | Sky HD | Vista Ulitmate Media Centre | Varilight Remote Dimmers | My bedroom setup
Rob_Meister is offline   Reply With Quote
Old 24-01-2008, 1:56 PM   #2 (permalink)
MarkP80's Avatar
Thanks: Gave 92, Got 76
Re: Extending IR to front of room
Hi Rob,
Keane electronics do an IR repeater. Basically you have an IR receiver at the front of your room (next to the TV, or somewhere convenient. This is then hard wired back to your equipment area, where it plugs into the "control" box. From the control box, you plug in the IR transmitter, which retransmits the IR to your equipment.
Fairly straightforward system, only hassle is running the (v thin) cable to the back of the room - I was able to route mine under the floor.
I bought their optional receiver which looks like a blank socket faceplate, and is quite neat. The standard unit is a black box, like a rounded off matchbox I suppose.
HTH,
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
Old 24-01-2008, 4:41 PM   #3 (permalink)
Having trouble finding this repeater. Do you have a link anywhere?
Thanks.
Old 24-01-2008, 4:57 PM   #4 (permalink)
dunks517's Avatar
Thanks: Gave 360, Got 283
Here you go Rob:
http://www.keene.co.uk/electronics/m...mycode=IRBKITS
Assorted gear: Panny 42TH PX70, B&W Speakers, Kef HTB 2 Sub, Linn Diskreet speakers, multiroom Sky+ HD, PS3, Tosh EP30 HDDVD, Acer iDea 500 HTPC, Sennheiser HDR-120s, network gubbins, Xbox360s, Wii, Harmony 525, 360 & One.
My Av-centric home
dunks517 is offline   Reply With Quote
Rob_Meister (24-01-2008)
extending, front, room
