AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 24-12-2007, 10:12 AM   #1 (permalink)
Thanks: Gave 14, Got 6
4 gang wall sockets - do they exist?
I've been searching the web to no avail.
Is it possible to get a 4 gang switched wall socket to replace a current 2 gang one? I've found a triple but thought that I may as well go to 4 if they are available.
I want to use a couple of Homeplugs but am aware that they don't recommend using them with trailing sockets. If I dedicate 1 socket to the plug then that means having everything else hanging off the one remaining socket!
Vorix is offline
Old 24-12-2007, 10:19 AM   #2 (permalink)
Thanks: Gave 6, Got 92
Re: 4 gang wall sockets - do they exist?
http://www.screwfix.co.uk/prods/6088...-Skt-Converter
ukbootlegs is offline
Old 24-12-2007, 11:26 AM   #3 (permalink)
Thanks: Gave 2, Got 5
Is it ok to shorten the cable on a 4 gang trailing socket or do they have to have a fixed amount of cable on them?
The one I have has about a metre of cabling on it and I would like to shorten it a bit to make things look a bit neater?
gillw is offline
Old 24-12-2007, 11:51 AM   #4 (permalink)
Originally Posted by ukbootlegs View Post
Thanks for this - have you used one of these? Is it one that just clips over the existing double socket or do you remove the faceplate and have to rewire it in? Looks tempting regardless......
Vorix is offline
Old 24-12-2007, 12:27 PM   #5 (permalink)
couldnt tell yer m8
i saw your post and thought if anyone sells them then screwfix does and took a gander on your behalf
Old 24-12-2007, 2:23 PM   #6 (permalink)
Beaker's Avatar
Thanks: Gave 1, Got 7
Gillw, you can shorten the flex if you know how to rewire a plug, or in side the 4way block. There is no limit on shortness. It is more to do with coiling wire up like in a cable reel.
Beaker
Beaker is offline
gillw (24-12-2007)
Old 24-12-2007, 2:30 PM   #7 (permalink)
Thanks: Gave 6, Got 55
Have you considered just putting another 2 gang next to your existing 2 gang
lowmans100 is offline
Old 24-12-2007, 2:52 PM   #8 (permalink)
Thanks: Gave 1, Got 1
Plugs straight on to existing single or twin socket
gasspark is offline
Old 24-12-2007, 2:56 PM   #9 (permalink)
This is all true but if you have the knowledge wire the block keeping the moulded plug, this is for the safety of others.
gasspark is offline
Old 24-12-2007, 10:53 PM   #10 (permalink)
Beaker
Thank You.
Merry Christmas to you all.
gillw is offline
Old 01-01-2008, 10:22 PM   #11 (permalink)
Bought a 4 gang and a 3 gang block from Screwfix and just wired them in to the existing 2 gang box in the wall. They are cleverly designed so that the screw holes match. One thing to note is that they sit quite a lot more proud of the wall than the old socket.
I also bought the Homeplugs and these are working perfectly in the new sockets.
Thanks to all for your help.
Vorix is offline
Old 04-01-2008, 2:46 PM   #12 (permalink)
Thanks: Gave 6, Got 14
great, i didnt know these existed either. In my new house theres only one outlet in the three bedrooms so these will be ideal for me
thanks!!!
the_watcher87 is offline
exist, gang, sockets, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall sockets and cables gurjy Interconnects, Speaker Cables and Switches 1 08-10-2007 1:58 PM
unswitched wall sockets godzilla1 Home Automation, Lighting, Security, Heating and Cooling 15 03-10-2007 2:57 PM
Power Extension Cable 10 sockets 5m cable, do they exist? mattressback Interconnects, Speaker Cables and Switches 5 06-02-2007 3:13 PM
wall sockets Tracey Home Cinema DIY 9 03-10-2003 1:49 PM
Wall Sockets for Speakers Malone Speakers 3 08-09-2002 1:12 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
