New Room
I'm starting a new home cinema project - setting up as 5.1 rather than 7.1. I've some experience having done one before.
Room is 16'11 by 16'2, and has a slight L-shape to it as the door & 1 wall come out about 2'. The main area used will be about 16'2 by 14'2 wide.
I'm keen to avoid floor standers (I have some B&W 604's) but don't want to spend a fortune on fitting in-walls. My partner would prefer maximising room space, the room is a little on the acoustic bright side, but may settle once wall coverings & furniture are in place. (prob amenable to acoustic treatments)
Question ---> Are in-walls or on-walls as good as my 604's ??? (Using a Denon 3803 at moment)
If so, can people recommend suitable in-wall or on-wall combinations for me to look into & audition??? As the seating is near the rear wall I may need to use dipoles on the left & right surrounds.
Budget for speakers must be kept down to less than £700 really, hence the above query, is it possible to get good 604 level performance from in-walls or on-walls at that budget - I suspect not!
Ian
Sim2 Domino 30 / Vutec Vu-flex Pro 7' / Panasonic TH-42PW5B / Denon 3803 / Sky+ / Denon 2800Mk2 / HTPC / B&W S3 604 x2 / B&W LCR600 x1 / B&W 602.5 x2 / B&W LCR60 x2 / Futronix P800 / Atacama Equinox / Lots of cables / Plenty DVDs
