Hi there. I'm in the early planning to wall-mount an LCD TV and 5.1 speaker system in our sitting room (rectangular 5.8x3.5m). I think that this is a very simple job, but I've never done this before so I figured I'd ask some questions to the experts.
The room has been stripped of wallpaper and new engineered wooden flooring will be put in at a later date. The wall where the TV will be mounted is a plastered external brick wall.
Currently the room is storing DIY stuff while we finish the decoration in the rest of the house
Front of room:
Back of room:
I am planning on buying the following equipment
TV: Samsung 32/37/40" LCD - haven't decided which size yet
Mount: PLB105M Super Slim 30-55" LCD/Plasma TV Wall Mount or Allcam LM28 Slim 15" -30" LCD TV Wall Mount Bracket - haven't decided
AV amp: Onkyo 508 - only need 5.1
Speakers: Jamo - they look nice
DVD: Toshiba SD370E - until HTPC configured and more wife friendly
Mac Mini: HTPC for PVR, etc.
Plan:
I have been reading many of the other DIY project threads for inspiration and tips, but I already have a lot of questions. If anyone can help me along the way I would appreciate it - I promise lots of pictures of me destroying the room. I'm going to start after Christmas.
1) Can I run flat speaker cable for the rear speakers under the engineered wood floor that will be put in after I complete the room decoration? I think the cable is only about 2mm. I was thinking of running it directly from the front to the back walls (in a "V") and then chasing up the walls to the rear speakers.
2) Do I really need an SCART cable? I'm not from Europe so I really don't even know what SCART cables are used for. Without an SCART the cable channel in the front wall can be much smaller, no?
3) What is the best way to "chase out" the plaster walls? Someone suggested a drill and chisel. What about for the micro cable used for front and rear satellites? I only need a narrow/shallow channel.
4) What type of conduit would you suggest to protect the connection cables (HDMI/VGA/power/SVHS etc) and speaker cable? I think that it will be difficult to chase deep into the brick wall so I think that a drainpipe is out of the question. Also seems a bit overkill to put conduit for these wires?
5) Can I run an extra electrical socket as a horizontal spur from the existing socket (see the plan above)?
6) If I go with a slimline mount, I guess I will need to chase out some of the wall behind the LCD to allow me to connect the HDMI and VGA cables to the TV. Does anyone have any advice on these AllCam brackets?
Thanks very much!
Stephen
