AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 18-12-2007, 3:33 PM   #1 (permalink)
Thanks: Gave 7, Got 1
Mounting TV on Plasterboard Wall.
Not too sure if this is the right area, but I need a bit of advice.
My mum wants an LCD/Plasma for her front room, but the only wall she can put it on is made from 9mm or 15mm plasterboard.
Is there anyway I can get this to stay on the wall, as I fear it will be just plainly too heavy?
Any advice is welcome.
Thanks in advance.
atacam.
atacam is offline
Old 18-12-2007, 4:03 PM   #2 (permalink)
Thanks: Gave 5, Got 2
Re: Mounting TV on Plasterboard Wall.
If it's a timber frame type house (i.e. there are solid wooden uprights behind the plasterboard every few feet) you can locate these and mount horizontal wooden battens onto them (you can even cut out the plasterboard and sink them in so they do not push the TV too far away from the wall). Or if your lucky like I was, you may find that the screw holes on the mounting bracket naturally line up with these wooden uprights. As long as you have screws long enough to go through the plaster and well into the wood you should be fine.
There are also a myriad of different fixing types suitable for plaster board, but I would not like to put faith in these only.
Sanyo PLV-Z4, Draper Luma 7', Panasonic DMRES10, Cambridge Audio Azur 540R, Mission M52, M50C, M7DS, Panasonic TH37PE50, Philips Streamium SL300i (and a dead WMA11B)
"Never rub another mans rhubarb"
DavidPeat is offline
Old 18-12-2007, 6:22 PM   #3 (permalink)
Thanks: Gave 4, Got 32
The short answer is yes you can mount it on that wall!
My advice would be to use the 'search' facility on this site , there is 100's of posts identical to this one on this site
Jon
Jon Boy is offline
mounting, plasterboard, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall mounting a 26" LCD to a Plasterboard wall (not your usual..) PulseTurbo LCD Brackets and Mounts 5 12-11-2007 4:32 PM
Wall mounting on plasterboard jgreatrex Plasma Brackets and Mounts 5 10-10-2007 8:15 AM
Plasterboard wall....should i bother wall mounting??? patrickyuis Plasma Brackets and Mounts 6 06-06-2007 12:26 PM
Mounting plasma to entirely plasterboard wall.. steelydave Home Cinema DIY 5 26-04-2006 5:14 PM
Mounting on plasterboard wall makey Home Cinema DIY 2 05-07-2005 3:56 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
