AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 15-12-2007, 10:11 PM   #1 (permalink)
Thanks: Gave 58, Got 18
portable heating
hi
can anybody help
im after some portable heating which would heat my loft home cinema,the space is 24ft x 12ft,floor/walls/ceiling will all be carpted,in summer its warm up there which i can use a electric fan for cooling but in winter its freezing so i need a portable heater which i can just plug in to take the cold edge off.
i have a budget of £100 is there anything in this price range,i dont need it to be a sauna in the room i just need it to be comfetable
and links fleabay/b/q or anywhere else
cheers
mr gothic is offline
Old 15-12-2007, 10:57 PM   #2 (permalink)
Peridot's Avatar
Thanks: Gave 73, Got 41
Re: portable heating
I'd recommend electric oil-filled radiators. They warm-up reasonably quickly, have good thermostatic control, and are probably the most efficient of any electrically powered heater.
Good range here.
I'd go for a couple of the DeLonghi 2kW ones that are on special offer.
You may also pick up second-hand ones on fleabay / freecycle. They're fairly indestructible so an old one should still work fine.
Peridot is offline
Old 15-12-2007, 11:06 PM   #3 (permalink)
hi
plenty to choose from
the delongi at £39 special offer do you recomend,would 2 of those be ok
thank you for reply
Old 15-12-2007, 11:30 PM   #4 (permalink)
Originally Posted by mr gothic View Post
hi
thank you for reply
sorry £32.97 delonghi special offer is this the one
Old 19-12-2007, 10:03 AM   #5 (permalink)
Peridot's Avatar
Not ignoring you - never received e-mail notification of thread update
Yes, they're the ones. The more expensive ones have more sophisticated controls, but the basic operation is the same.
Peridot is offline
mr gothic (19-12-2007)
heating, portable
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Over heating? RICHIE511 PS3 3 19-09-2007 2:29 PM
360 Over-heating? ohh_danielson Xbox 360 7 24-02-2007 10:33 PM
Biomass heating, carbon neutral central heating. Johnnie Reducing Your Carbon Footprint 1 03-01-2007 1:31 PM
Gas Air Heating GagHalfrunt CRT Projectors 2 29-01-2003 5:56 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
