My 'minimalistic' wall mount and home cinema setup
Started my install project this weekend so thought I would share. The idea is to have just the 50" plasma on the wall with all AV equipment in the next room and no wires in sight.
Equipment list
50" Panasonic Panel
Onkyo 605
Jamo HC10 speaker system
Toshiba EP35
Sky HD
harmony 895 remote
PLB105L Super Slim 36-70" LCD/Plasma TV Wall bracket
The wall is plasterboard with thermolite blocks and 1cm-ish air gap. I wante to recess the bracket such that back of TV would be flush with wall
Re: My 'minimalistic' wall mount and home cinema setup
Ive just bought that bracket.
Ebay?
I take it your not going to use the securing bar.
Ive got a similar dillema as my tv is mounted in the wall (tv alcove of sorts) and i dont have access to the sides.
Yes, I am not going to use the securing bar (don't see the point to be honest)
I hit a slight snag today in that I also need laptop connectivity to the plasma and as it has a vga connector and I was just going to drop a vga cable and run it along with other cables. Unfortunatly the vha connector is 4mm thicker than my plasterboard/breezeblock gap so I am now looking into making my own vga cable. That is, I drop the cable through the gap and then solder the vga connector to each end afterwards. Will see how i get on..
Ebay?
Interesting project haf63, interested to see how it turns out. I also just ordered that bracket (through Amazon). Too much work for me to sink it in like you - as I am mounting onto a brick wall!
The securing bar is there to stop thieves walking off with the TV. Not sure as to how it does it as i haven't bothered to look into it.
With a brick wall, you are wise to just mount it on the wall as the big attraction with sinking the bracket is to enable the cables to be hidden in the gap.
I plan to finish the install at the weekend so will post an update. Am currently trying to solder 15 tiny wires to a vga connector and in need of a big magnifying glass!
Got the TV finally up and running so here are some more pics.
The bracket with cables for vga, 2 x hdmi, power and power for led's. The vga was too tight for my gap so had to strip the moulding around the cable ends and squeeze it through.
Have still to finalise the skirting boards but will do that after sky HD install on tuesday. I will then tidy up the HD DVD and Onkyo 605 in the next room. Still waiting for the harmony 895. Also getting DVE to do some calibration..
Looks like amazon/post-office have lost my harmony so they are sending me another today, which hopefully I will get by the end of the week!
Will post some 'final pics' later as the sky hd install happens today and then i can cleanup the skirting etc. All in all i'm impressed with the results.
Excellent progress - quite the DIY epxert it seems!
How do you plan to control the equipment in the nxt room with a remote control whilst sitting and watching television?
The harmony 895 uses RF and has IR 'wands' that you place with the equipment. I've been assured that it should be no problem going through walls etc. Plus i can program it to make it easier for the wife to use
I have even got a RF power socket so i can control the led lights via the remote as well.
My 'minimalistic' wall mount and home cinema setup : final pics
pretty much finished the setup now. just carpets and settees to change and minor things like painting the skirting boards
I'm particularly pleased with my vga port thats coming out of the skirting. It makes it easy to connect a pc for viewing photo's
I've also included some pics of the av equipment in the next room.
All in all its been an interesting project and the final result has been very different to my thoughts before i got involved in this forum. finalview.JPG finalview2.JPG pc-connect.JPG av-equipment.JPG av-cabinet.JPG
