AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 07-12-2007, 1:29 PM   #1 (permalink)
Question BT Master socket move and upgrade.
I have read a few threads on these forums, but none seem to answer exactly what I want to achieve.
I own an old property where the BT line into the house is off a telegraph pole and the wire runs down the outside of the house to a master box (very old style) and then more wires are taken from this box back out to further extensions around the house. All wires are run on the outside of the property.
The master box is mounted on the inside of my front door frame, so a hole has been drilled through the frame and the wire feed through to this master box.
Now...I am having the door and frame etc replaced and do NOT want this new oak frame drilled into. I therefore want to put a new NTe5 style master socket with inbuilt ADSL filters mounted on an inside wall approx 2.5 metres from where it is currently.
The wires on the outside of the house will be long enough and I can actually probably run them neater to the new position.
My question is...What is the best way to get a new style NTe5 Master socket fitted. I have just spoken to BT India and they are so unhelpful but still require £150 for this to be done.
I am happy to do it myself. Could someone recommend the best way to go about doing this and what I will need. Thanks
I have attached a pic of what I currently have.
Groover is offline
Old 07-12-2007, 6:07 PM   #2 (permalink)
Thanks: Gave 208, Got 214
Re: BT Master socket move and upgrade.
In my last house I had some ancient small brown box that my phone was connected directly to (IIRC). I got hold of a master box, which was a task in itself at that time, but I think B&Q, etc sell them these days and connected it myself to the brown box, allowing me to plug in a 'modern' phone and return the rented BT one. (Did say it was a while ago).
I can't remember what colour the wires were in the small box or even how many there were, but as I wasn't on the net at the time I probably got the wiring info by looking at a friend's master box. Nowadays, we have Google, so see the link I've posted for details.
http://www.wppltd.demon.co.uk/WPP/Wi...telephone.html
Hope this helps.
Panasonic AE3000, 112" wide 2.35:1 Beamax Electric Screen, Sony 40W2000, Sony BDP-S350, Denon 2808, PMC DB1+ fronts, M&K K4 & K5 surrounds, BK Monolith Subwoofer & detached house.
KelvinS1965 is offline
Old 07-12-2007, 6:18 PM   #3 (permalink)
Cool, thanks Kelvin. As I thought. Just now where to get a BT master box, I'll try B&Q or there are loads of online retailers I see selling this related hardware.
Groover is offline
Old 07-12-2007, 6:35 PM   #4 (permalink)
Glad to be of help, forgot to say 'Welcome to the forums'.
Found this in Maplin, but I'm sure B&Q have them too:
http://www.maplin.co.uk/Module.aspx?...20box&doy=7m12
Old 07-12-2007, 10:28 PM   #5 (permalink)
Thanks: Gave 2, Got 6
Your breaking the law by modifying the existing cabling like that. It will be obvious too because any NTE5 you buy will not have the BT logo on it
gazzerdaman is offline
Old 07-12-2007, 11:26 PM   #6 (permalink)
Thanks: Gave 1, Got 10
There's loads of BT branded NTE5 boxes on ebay.
I wouldn't give 2 ***** about BT or breaking the law. Moving a master socket has gotta be one of the easiest DIY jobs you can do so why pay BT £150?
When you move it, you run the risk of getting a slight shock if the phone rings while you're doing it. Therefore, do it late at night.
mark88 is offline
Old 08-12-2007, 1:18 AM   #7 (permalink)
Thanks: Gave 0, Got 8
i have just done what you are on about for an uncle of mine.
buy an NTE5 socket off ebay and an NTE2000 faceplate if you intend running ya broardband off it
connect white with blue stripe to A
connect blue with white stripe to B
simple as that
orange with white stripe is the ring wire and does not need connecting
hope that helps ya dude
ukprometheus is offline
Old 09-12-2007, 9:06 PM   #8 (permalink)
Thanks: Gave 12, Got 11
I work for BT doing exactly what you want done for a living, PM me and I may be able to offer you some advise.
Lee.
Onkyo 605, Q-Accoustics 5.1, Sony Ps3 40gig, psn ashber100, Tosh 32WL56, Tosh RDXS34, Standard sky, Bt Vison (poo), Bt Home hub, Harmony 525, 60gig iPod video & dock.
And all connected together by wet string (albeit expensive string) !
podhead is offline
Old 12-12-2007, 4:40 PM   #9 (permalink)
Chuck_Norris's Avatar
Thanks: Gave 61, Got 18
Lee.
very helpfull, well done Lee
Chuck
Chuck_Norris is offline
Old 12-12-2007, 4:52 PM   #10 (permalink)
Ben
Ben's Avatar
Thanks: Gave 1, Got 176
Just to add - a great explanation (and can be ordered) from here
Ben is offline
Old 13-12-2007, 2:02 AM   #11 (permalink)
simple as that
hello good people
need some help I am trying to fix ADSL MASTER FACEPLATE SPLITTER to improve the connection and to avoid dropping of connection to the BT MASTER socket. I have also connection going to the first floor from master socket.
socket has 1 green/white 1 blue/white 1 orange/white 1 white/orange 1 white/blue 1 white/green
adsl master faceplat splitter has connector 2, 3, 4, 5, A, B.
when i opened the socket I thought i had some idea where these wires should go as they were all connected to BT MASTER SOCKET which had connector 2,3,4,5 only.
If i use the standard advise given here(i.e blue/white to connector 2 white/blue to connector 5 etc) then first floor phone does not work.so obviously something is wrong. I have very limited knowledge of this will appreciate any help all I need to know is where these wires go...many thanks in advance
mazmas
mazmas is offline
Old 13-12-2007, 1:36 PM   #12 (permalink)
Sorry all for the delayed reply, I have been away on business. Thanks for all the comments, very helpful and I shall now give this a go.
I understand that BT don't want me performing this task, but I'll be ****ed if I am giving them £150 to do a 10 min job. Their customer service and my initial enquiry was handled so poorly they don't even deserve the business. I am sure I can get a BT branded NTE5 master box from somewhere.
Groover is offline
Old 14-12-2007, 10:21 PM   #13 (permalink)
Spoonboy90's Avatar
Thanks: Gave 24, Got 14
Originally Posted by mazmas View Post
hello good people
mazmas
You also need to connect the Orange/White to #3 for the ringer. Failing that just open both sockets and just ensure you have the same colour wires going to the same numbers on each socket.
Spoonboy90 is offline
Old 15-12-2007, 8:40 AM   #14 (permalink)
I have now sourced an original NTE5, BT logo'd master socket. All bases covered
I will be installing this when it arrives next week I hope.
Groover is offline
Old 20-07-2008, 10:19 AM   #15 (permalink)
Hi all,
This is my first post and would really appreciate some help!
I have found the main phone line that enters my flat, and it attaches to a small panel rather than a NTE5 Master socket. All of my phone extensions are connected to this small panel also (It looks like a really old set up).
I do have an original BT NTE5 Master Socket at hand, and I was wondering if it would be an easy job to hook up the main wire to this, instead of the small panel?
As it stands, I don't have a test socket for checking BB speeds, testing line etc.
I did think that as I have a BT line, but no master/test socket, that BT would fit one for free...but apparently it would cost me £116 callout, £99 per hour after).
Any advice would be really appreciated (what wires go where ect)
Thanks guys.
diverse180 is offline
master, move, socket, upgrade
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Router not pluged into master socket- Does it matter ? R1CHARD Internet Service Providers (ISPs) 8 09-12-2007 10:19 AM
BT master socket and line attenuation Xusia Of Delos General Chat 11 01-07-2007 4:54 PM
Need to move a phone socket Decadence General Chat 3 26-05-2006 11:40 AM
Help - Need to move NTL socket Alan1975 Virgin Media 1 12-11-2005 3:53 PM
Extend a power cable or move the socket? PSH16 Interconnects, Speaker Cables and Switches 1 23-04-2005 11:38 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
