AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 06-12-2007, 3:37 PM   #1 (permalink)
Thanks: Gave 7, Got 0
Wiring behind plaster board wall? Dib Dab??
I live in a new built semi detached and want to hang my lcd in on my living wall which seperates me and my neighbours house.
It is a plaster board wall but there does not appear to be any consistenet spacing for joists (eg when i know on the wall you get hollow and solid sections spread all over the wall - does not appear to be single floor to ceiling joist - is this a dib dab wall?)
I want to position lcd in the middle of the wall and the various electric units placed by the corner of the wall.
I was hoping to drill holes at each end and fish the wire through wall however dues to inconsitent hollow/solid bits not sure if wires will simply fish through.
Can anyone please help with alternative options? A friend has suggested taking skirting board off, cut a bit off the plasterboard and run wires along the bottom. Is this the only option due to nature of the wall?
LionKing is offline
Old 06-12-2007, 4:01 PM   #2 (permalink)
Thanks: Gave 4, Got 875
Re: Wiring behind plaster board wall? Dib Dab??
What about trunking?
http://www.tlc-direct.co.uk/Main_Ind...ing/index.html
Andy98765 is offline
Old 06-12-2007, 6:10 PM   #3 (permalink)
Thanks: Gave 208, Got 214
My walls are the same and I managed to feed my rear surrounds by passing an old metal tape measure down behind the plaster board (took the right angled metal tip off it first). The tape came out behind the skirting which I'd removed, so I then used masking tape to stick the cable to the end of the tape measure and pulled it back up inside the wall. I was lucky that there was a gap between the dobs of adhesive. You might find you can do the same horizontally ( if I understood you correctly). If you are unlucky you may have to chase where you hit the adhesive, then patch it in after, like I did over my patio door to get to the last speaker. Also scart leads are too thick for the connectors to fit, you might get away with HDMI and component.
See my thread (post number 12 if the link doesn't work right) to see what I mean:
KelvinS1965's setup.
Hope this helps.
Panasonic AE3000, 112" wide 2.35:1 Beamax Electric Screen, Sony 40W2000, Sony BDP-S350, Denon 2808, PMC DB1+ fronts, M&K K4 & K5 surrounds, BK Monolith Subwoofer & detached house.
KelvinS1965 is offline
Old 06-12-2007, 9:39 PM   #4 (permalink)
Thanks: Gave 0, Got 8
Dib dab ??
Yamaha DSP-AX757SE/Denon DVD-1910/Sanyo PLV-Z2/96" DIY Screen/Mission v62 fronts/Mission v6c centre/Mission v60 rears (2 pairs)/Modded Xbox/PS2/Server PC
paulw77 is offline
board, dab, dib, plaster, wall, wiring
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall Mounts On Plaster Board MD_London Plasma Brackets and Mounts 14 23-06-2008 6:21 PM
Mounting 32 LCD on Plaster board wall abb16ott LCD Brackets and Mounts 5 20-11-2007 5:52 PM
Hanging a 37" LCD on a plaster board wall.... Capes LCD Brackets and Mounts 2 05-06-2007 8:54 AM
Wall Mount and plaster board Bubblin LCD Televisions 4 30-11-2006 10:49 PM
Wall mount through plaster board Richard78 Home Cinema DIY 6 20-04-2006 11:40 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
