01-12-2007, 11:19 PM
#1 (permalink)
Thanks: Gave 11, Got 5
Kitchen Dining Room Conversion with AV tbd
What we are intending to do is knock down the wall between our kitchen and dining room and create a much larger kitchen/living space. This is a tenuous thread on the forum at the moment, since the AV side has yet to be decided, but the aim is to include a plasma in what was the dining room. I have enjoyed so many of the threads in this section, that I thought it only fair to start one myself on this (largely) DIY project.
This was the dining room
And this was the kitchen
Reason: replace with embeded pitcures
01-12-2007, 11:42 PM
#2 (permalink)
Re: Kitchen Dining Room Conversion with AV tbd
Well I'm not sure how to get inline photos, so will make do with these attachments for the time being. <edit, have now altered to embedded images as these seem much more agreeable>
Progress to date.
In preperation for the builder to remove the wall, we have removed all the plasterboard from the joining wall, moved electrics out of the way, completely taken out a radiator and removed some of the kitchen units. Its amazing how long it takes just to trash a room. This was the views this morning.
and this is the RSJ waiting to go in
01-12-2007, 11:49 PM
#3 (permalink)
Since we disappeared most of the day, still trying to decide on flooring, radiators, kitchen worktops and more, I didn't get many pictures of the boys at work, but I've got one of them nearly complete.
So now its time to start making good.....
05-12-2007, 11:14 PM
#4 (permalink)
Thanks: Gave 10, Got 20
Cant believe this thread,exactly what I am going to be doing in January,
Keep it going,with loads of pictures please
Best of luck
Kev
06-12-2007, 3:50 PM
#5 (permalink)
Can't believe you dont want to start it just before Xmas!! I've made a little more progress, but not much due to work comittments. Will post some more pictures soon. I've still not had much time to think about the AV side as so many kithen bits to finalise. We are trying to make up our mind on the work top at the moment. Currently undecided between Granite, Granite transformation (thin layer of granite on top of existing worksurface) or a product called Smartstone. The latter is the only DIY option, but cant find many retaillers selling it, except Travis Perkins who are rediculously expensive and an online company (onefitappliances) who are much cheaper but don't have all the bits I want. Moral of the story is do all the research before you lift a screwdriver (but I dont practive that myself)
Andy
26-12-2007, 2:54 PM
#6 (permalink)
Back from the dead, or that's how I've largely felt over the last few weeks, sometimes working until the wee hours trying to get things ready for the electrician or plasterer who is coming the following day. My intention was to keep regular updates on the progress of this project, but I've just not found the time to do so. So here's a big dump of photos I've taken so far. The pictures are now embedded so that should make for easier reading.
I'll start with a couple of photos which I use to remind me that just occasionally luck is on your side. Some years ago I modified the old kitchen, moving units around rather than replacing them as they weren't really in that bad a condition. This was what I found whilst removing the plasterboard behind 1 wall unit!
and from below, it really doesn't get much closer than that
After the main wall was down, one of the first jobs was to remove the old tiling in the rest of the kitchen. Now, being dry lined, its fairly difficult to get the tiles off without destroying the platerboarding behind, so this time I didn't try, but just cut the the whole lot out.
What is left is the battening that I used last time I modified the kitchen tiles. Not a very elegant solution, but since I was just retiling, this seemed an OK way to do it.
There were some radiator pipes that needed dealing with, the old kitchen radiator that had been capped off last time and the dining room radiator that is no longer required. If you look at this picture, the return pipe has a compression end on and this will be used later to connect a new radiator in the dining room area, the flow will be taken from the capped off old kitchen radiator pipe.
The central lights were being replaced with downlighters. The elctrician was happy for me to do all the donkey work, cutting holes and running cables, whilst he just makes the final connections. I have to admit that I initially was a bit annoyed at the new regulations, but with hindsight they do make sense and ensure that the enthisiastic DIYer doesn't take any liberties!
Time to get one of the youngsters doing some work
Holes cut, cables run ready for electrician to come and do the lighting
And here the downlighters have been connected, still some repair work to be done on the ceiling, but I'm hoping to get away with replacing the plasterboard plugs that have been cut out and then skim over them and repaint. I've done this before with some degree of success.
and this will be the pendant light over the kitchen island. There are half a dozen individual lights that can be adjusted in lengths. Just one is connected so far to test it
Boxing day lunch calls, will continue with photos later
26-12-2007, 4:36 PM
#7 (permalink)
Thanks: Gave 307, Got 265
Hi Andy
I can`t decide if working on a boxing day is dedication or daftness but you seem to have it all in hand so keep it up and good luck with your project
cheers Allan
Click to see my selfbuild/basement cinema
Onkyo TX-NR 905 M&K`s SW150 fronts SW95s rears Sub M&K MX125 Mk 11 SIM Grand Theatre PJ 118" 16.9 fixed screen HTPC Asus AMD2 6000+ CPU LG BD/HD player 4gb DDR2 Ram 5t/b h/drives Panny TH-50PX70 / TH-42PX70 Samsung LE40A756/BD-P 1500 Humax Freesat HD
26-12-2007, 4:59 PM
#8 (permalink)
Thanks Allan, though just to get the story straight, I'm not actually working today, just taking the time to update the thread with some pictures!
Next step was to build a temporary kitchen in the dining room area, just to allow us to cook until the new units arrived.
There were some problems with the levels between the 2 rooms and especially one big dip that I hope is now OK, since we intend to lay a kind of tiled laminate that will require everything to be pretty even.
And some more work involving filling a small "trench" where the wall was taken down
I'm really trying to avoid taking up all the tiles in the old kitchen area, so the difference in height should now be just 1 layer of underlay so I'm hoping that an extra layer in the old "dining" room area will then make everything level
26-12-2007, 6:57 PM
#9 (permalink)
The old kitchen door needed to be closed up. So first some stud work was added
Then plasterboarded
Now an attempt to dab and dob (or is it dob and dab?). This was where things went a bit wrong. Never having tried this before, it was probably a bit ambitious to try a large horizontal area as a first try. This is the second attempt and although it looks OK in the picture, it is actually bowed, and later had to be removed
The first attempt was a bigger disaster, I used some old dry liner adhesive, which looked fine but went off in about 5 mins, before I even had time to get the plaster board on the wall!
So for the 3rd attempt, I used 3 vertical pieces and this was pretty much OK
Then a start on boxing in the RSJ and the pillar's at each end
Finished boxing
The dab and dob technique is not quite as hard as it seems, the adhesive is quite awesome stuff.
26-12-2007, 7:32 PM
#10 (permalink)
This is now all that is left of the old kitchen
The plasterer came on the friday before Xmas and made a dramatic transformation but, do they make a mess, there was as much plaster on the floor as on the wall
Seems a shame that most of this will eventually be hidden
Ikea kitchen arrives, 145 pieces (all as ordered, well done Ikea). They scan each piece as it is unloaded and provide you with an itemised delivery note, which is just as well, as you otherwise wouldn't have a clue what was there.
Lounge taken up as an assembly area. Now I have so say that the installation instructions date back to the dark ages of flat pack contruction. No words at all, as the instructions are trying to cater for multiple languages. Also since many of the units can have more than 1 configuration, each "manual" caters for multiple possibilitities. Probably wasted more than a day putting this stuff together, although I think its good once assembled
Old plumbing
And the new plumbing once the base units were installed
We decided on smartstone worktop. It is a stone faced chipboard that can be transparently joined and sanded to a fine finish. I had thought on trying to do this myself, but am really glad I didn't. Not only is it 'kin heavy, it also requires specialist tools to join. Any mistake would have been very costly.
The join is glued with coloured resin
this is allowed to dry and then sanded smooth
Top units installed and some of the appliances
Now this is where we finished Xmas eve, the doors still have their protective covering on since once removed they need to be washed and are somewhat delicate for 24 hours afterwards
The island, still needs to be put in its final position, we intend to run the flooring underneath before securing
and finally the Xmas turkey cooking and time for a couple of days rest!
So long for now
04-01-2008, 12:53 PM
#11 (permalink)
Thanks: Gave 2, Got 2
Superb stuff.....keep it coming !!
06-01-2008, 12:00 AM
#12 (permalink)
Thanks: Gave 54, Got 23
Great work!
My wife seems to like your kitchen and now i have to do one........
06-01-2008, 1:32 AM
#13 (permalink)
Thanks: Gave 25, Got 56
Looks great. At first inspection I thought you had opted for a strange pattern on your kitchen cabinets but then realised it was the protective packaing
My Set Up
APPLE TV 250GB - ASK ME HOW!
05-02-2008, 6:54 PM
#14 (permalink)
Some more photos of the near finished project. Here's the floor going down. Its laminate with a tiled print. Sounds dodgy but the idea is to get a tiled affect along with a warmer feeling that comes from laminate.
Skirting gone in here
Some views of the finished room
OK so before starting any of this, I sort of thought that the back of the chimney breast here might be the location for a nice new plasma. However I seem to have met some resistance here. "God thats so American" (daughter) and "do we really need another TV" (guess who). So you'll notice the 2 chairs are now facing in the wrong direction.
I haven't given up on this idea yet, however I have initially decided to go for a different tack - I'm going to get a squeezebox/NAS/Amp and speakers to go in this area. Thats all for me - time for a bit of a rest
06-02-2008, 10:46 AM
#15 (permalink)
Thanks: Gave 51, Got 6
Nice work. Didn't think I would like light worktops and units, but they seem to work well. For a moment there I thought you had some kind of floral pattern on the doors!
One day I'll set up my 1271QM properly. One day........ One day...
