AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 30-11-2007, 8:26 PM   #1 (permalink)
Thanks: Gave 94, Got 67
A Tiny Big Screen Room
Hi all
Well I am about to adventure in to the world of Home Cinema (HT)
Ive loved movies an media forever and have always loved the big screen experiance, and finally have a spare room that I can claim as my own...
So here it is
crimsoneagle is offline
Old 30-11-2007, 8:34 PM   #2 (permalink)
Re: A Tiny Big Screen Room
Nothing fantastic is it.....
Yet....
I currently have the following equipment
Mission M35 fronts
Mission M3DS rears
Mission V6C centre
Yamaha 750SE Amp
PS3
HD DVD through my HTPC
3.2Ghz Core Duo (e6600 OCd)
4 Gb Ram
500Gb HD
8800 GTX
And currently have on order
Panny AE2000U
BK Monolith
2x BK Transducers
Anamorphic Lense
This is my first foray in to real serious HT and would love advice on my current kit and what I can do to get the best possible experiance, I have learnt a HUGE amount already and look forward to havin a real BLAST!!!!
I will post my room plan and dimensions soon.
Any ideas are greatly appreciated...
Old 30-11-2007, 8:38 PM   #3 (permalink)
Thanks: Gave 2, Got 6
Hi and welcome to the forums.
By the list of the kit you have and have ordered you will have great system! Don't worry about the room size, just set it up properly and it will be stunning.
All the best
Nick
Roksan Kandy 3 Amp, Roksan Kandy 3 CD, Yamaha RX-V750 Amp, Monitor Audio Silver S5, Monitor Audio Radius Centre and Rears, Cub Subwoofer, XBOX 360, Hitachi 37" Plasma & Sky HD (self install of course)
curvature is offline
Old 30-11-2007, 8:59 PM   #4 (permalink)
I know this isnt the place to ask but can anyone recommend some cheapish speaker wire and banana plugs.....
bout the only thing I havent thought about..
Old 01-12-2007, 12:43 PM   #5 (permalink)
Thanks: Gave 38, Got 14
Have a look at vandamme cable - it's quite reasonably priced (I got mine from clearly-av.co.uk) and CPC for banana plugs (they do quite a few different types).
Mr. Wilby is offline
crimsoneagle (01-12-2007)
Old 01-12-2007, 5:11 PM   #6 (permalink)
QED is very good.
If you want a cable that is easy to hide their micro series is excellent.
It also holds a bend very well and if you are putting it up in a pre-decorated room i actually glued it to the uderside of the coving and to the top of the skirting board. You would never know it was there!
About £1 a metre from memory. They also do a biwire version.
Old 01-12-2007, 6:08 PM   #7 (permalink)
Thanks guys have not had the chance to get my room plan up as my main PC has died...
I think the mobo has gone just wont post .....
Damn technology..
Well just hope I can RMA and get it back b4 xmas . . . .
Old 01-12-2007, 9:04 PM   #8 (permalink)
Thanks: Gave 292, Got 207
Looks like a cracking good room you have there, i would like agree with Mr. Wilby CPC for banana plugs and for part rolls of cable Clearly AV (If you want a full 100Mtr roll CPC is cheaper, but they won't split rolls) Both are great company's and deliver next day (you need to spend £40 with cpc and £50 with Clearly AV for free delivery by the way.....)
Good luck......... Deano
dbs2 is offline
Old 04-12-2007, 6:32 AM   #9 (permalink)
Ordered cables and interconnects as per the advice given by you guys got van damme 2.5 and cpc interconnects..... also found a way under the floor to hide away all the speaker cables, and my HUGE 450mm shelf brackets have arrived.
Im going to mount the PJ Lense and most of the equipments up high behind me (HATE LED DISPLAYS AND LIGHTS).
have painted my undercoat.
Lense arrives today will post pics when I can..
its all coming together...
Old 04-12-2007, 7:52 AM   #10 (permalink)
Sounds great already crimsoneagle, you seem to be not hanging about at all
Where are the pics then
dbs2 is offline
Old 04-12-2007, 9:50 AM   #11 (permalink)
Will post'em tnite
Old 11-12-2007, 11:58 AM   #12 (permalink)
I have a mounting problem my Aussiemorphic lense has arrived and after heated debate with the missus have decided to ceiling mount the PJ and the Lense it is HUGE!!!
The best way I can think of doing this is to mount the two together on a large piece of MDF then mount the MDF on the ceiling im thinking of getting this basic mount from ebay
http://cgi.ebay.co.uk/UNIVERSAL-LCD-...QQcmdZViewItem to secure the PJ to.
Any ideas anyone for securing the PJ & lense to the ceiling and/or how do I find wher the beams run in the ceiling without puntching hols in it??
Any ideas would be great guys...
BTW the pic with the LENSE LOOKS AMAZING!!!
even the missus commented
"that looks much better"
and trust me the woman is hard to please
Thanks all again
Old 11-12-2007, 12:23 PM   #13 (permalink)
You could always use a Wood Stud detector like Thisish
I cant say i have used one, but some people swear by them...... or was that swear at them
Deano
dbs2 is offline
crimsoneagle (11-12-2007)
Old 14-12-2007, 7:49 PM   #14 (permalink)
Hi all could do with some help with getting my screen up I have all of my equipment, the room is almost decorated and im not far from finished!
sorry no pics I dropped my camera!!!
guess you will have to put up with the finished product
anyways head over to the screens forum and see if you can help me
http://www.avforums.com/forums/showt...60#post6022060
Old 15-12-2007, 9:30 PM   #15 (permalink)
Cables are run new camera!!!
so should be gettin more pic on here!!!
ive run the speaker cables under the floor
big, room, screen, tiny
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Need new screen to replace my Tiny ! Bacus Plasma Televisions 11 25-02-2005 10:27 PM
Tiny home cinema room! glock339 Room Acoustics, Audio and Video Calibration 8 07-01-2005 5:22 PM
Samsung screen from Tiny workshy Plasma Televisions 3 13-12-2004 1:52 PM
Speaker Advice/Tiny Room butch9850 Speakers 2 06-12-2004 2:48 PM
Home Cinema in a tiny room Kid A All-in-one Systems 12 08-06-2004 9:52 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
