AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 28-11-2007, 12:46 AM   #1 (permalink)
Thanks: Gave 22, Got 14
Extension with Home Cinema Room
Hello all,
I never thought I would be saying that one day, but yeah!!! I am having an extension built and one of the room (Study) will be my dedicated Home Cinema Room / Bedroom to keep the wife happy. What I am trying to achieve it is a good all rounder sound and movies. Upgrade to full HD when finance permiting after this rather costly extension.
I want to be able to control everything from a good remote control like the Logitech Harmony 1000 in this room. And as we will go through major redecoration works and redo the electric, I will network the all ground floor with network points in every room for a Sonos system.
Ongoing HC Room build
Arcam AVR 350|Front: MA RS8|Rear: MA RS1|Center:MA RSLCR
Display: Panasonic PTAE-700E| 60GB PS3 PREMIUM| the rest to come
Geoxis is offline
Old 28-11-2007, 12:52 AM   #2 (permalink)
Re: Extension with Home Cinema Room - Day 2
Building work started this Monday and this is what happened so far. They managed to remove a nasty piece of concrete left over from the conservatory foundations that was at the back of the house.
Geoxis is offline
Old 28-11-2007, 6:33 PM   #3 (permalink)
THE_FORCE's Avatar
Thanks: Gave 660, Got 302
Hi there Geoxis . I'm gonna be watching this thread with great interest as I spent the first 12 years of me life growing up in good old Worcester Park !
If you decide to get a harmony 1000 and need any help setting it up then give us a shout and I'll do my bit if I can.
I bet it's changed a helluva lot since I was last there lol.
Good luck pal
Click here for my Home Setup Pics and Kit list
Main:Pio LX608D,Denon 4308,1930,DCD700S,Duo 77a's(7.1),Sky HD,PS3(60)+Wii,Harmony1000
Bedroom: Sony 46X3500,Yammy RX-V2600,Kef 3005SE's,Sky HD-multi,PS3(60),Squeezebox,Harmony555.
PC Room: Sony 40S2030(as monitor),Technics,Mission 73s,Vaio,Dinovo Edge
THE_FORCE is offline
Old 29-11-2007, 10:28 PM   #4 (permalink)
Dr Force's Avatar
Thanks: Gave 345, Got 201
Hi Matey
Looking forward to see this develop
Any chance of giving the internal dimensions of your Hc room??
MY HOME CINEMA
MY KIT:Mits HC6000 1080PJ,Hitachi 42PD7200,92" Grandview Screen,Sony STR3200ES,SVS 5.0,Wharfedale SW150 Sub,
ToshHD E1,ToshHD EP-30, HD DVD Add On,Sky HD & Xbox 360.
Dr Force is offline
Old 30-11-2007, 12:39 AM   #5 (permalink)
THE_FORCE's Avatar
now Geoxis, you've got twice the Force on ya case !!
Old 30-11-2007, 12:47 PM   #6 (permalink)
Originally Posted by Dr Force View Post
Hi Matey
Ok, the room dimensions are:
(Length) 5m x (Width )2.80m that makes it is roughly 14 square meters. Ceiling height I will be looking to achieve around 2.50m.
On the right hand side wall (when facing the window), because of the existing house structure, I cannot have the bit of wall coming of 30cm in the room changed to have a perfectly rectangle room - shame , but well, you can't have everything can you?
Geoxis is offline
Old 30-11-2007, 1:38 PM   #7 (permalink)
Dr Force's Avatar
You betcha!!! The Force is with you on this one, we have great expectations
MY HOME CINEMA
Dr Force is offline
Old 30-11-2007, 1:39 PM   #8 (permalink)
Dr Force's Avatar
Length: 5m x 2.80m that makes it is roughly 1500 square feet ceiling height I will be looking to achieve around 2.50m.
On the right hand side wall (when facing the window), because of the existing house structure, I cannot have the bit of wall coming of 30cm in the room changed to have a perfectly rectangle room - shame , but well, you can't have everething can you?
Thats a good size room, not too big and not too small. I personally prefer it at the size you have rather than it being large and less cosy.
Keep us updated with pics etc and we will help where we can.
MY HOME CINEMA
Dr Force is offline
Old 30-11-2007, 3:46 PM   #9 (permalink)
Yep I better have it on my side than against me... I won't disapoint I have great Jedi skills!
Pictures update later today...
Geoxis is offline
Old 30-11-2007, 4:44 PM   #10 (permalink)
Re: Extension with Home Cinema Room - Day 5
They have started the foundation work god it is a lot of mud. Considering they are doing it all by hand... They working pretty fast!
I have also attached what I intend to realise in my room, I hope it is clear enough...
Geoxis is offline
Dr Force (30-11-2007)
Old 30-11-2007, 5:01 PM   #11 (permalink)
mossym's Avatar
Thanks: Gave 21, Got 140
(Length) 5m x (Width )2.80m that makes it is roughly 1500 square feet ceiling height I will be looking to achieve around 2.50m.
1500 sq ft? you'll need one hell of a set of speakers...
My Home Cinema Room
My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 4* B&W 603, 2* B&W 602.5,B&W LCR600, Hsu STF-3. XBOX360 + HDDVD. HTPC for Blu-ray + HD Satellite
mossym is offline
Old 30-11-2007, 5:20 PM   #12 (permalink)
ooopss I got that wrong... I am more a metric than anything else, so I will edit this... thanks
Geoxis is offline
Old 30-11-2007, 5:52 PM   #13 (permalink)
THE_FORCE's Avatar
lol Ere Geoxis you're not anywhere near Kingsmead Avenue are ye?
Old 30-11-2007, 9:59 PM   #14 (permalink)
Dr Force's Avatar
This is the messy bit, but once its done you can look forward to watching it take shape.
Set up picks look great, well thought out and will give you hours of enjoyment.
Kepp it coming
MY HOME CINEMA
Dr Force is offline
Old 30-11-2007, 10:23 PM   #15 (permalink)
I am definitely not too far... is that where you grew up? Do you still have family around here?
Geoxis is offline
cinema, extension, home, room
