Like everyone else on this forum (it seems), I am building a false/floating wall to house my Plasma.
I've got about 15cm of space between the plasterboard and the brick wall.
Do I need to insulate this? It's an internal wall as part of an open plan room, so I'm not worried about the sound travelling into the next room.
My main concern is that the void may become boomy or vibrate ? Is this likely ? If so do I need to get anything specialist to dampen it or will normal loft insulation secured vertically be ok ?
I'll post pictures of my install if anyones interested in another false wall install.
Especially if you want to see a bodge-it-diy install
Ta.
