AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 25-11-2007, 8:04 PM   #1 (permalink)
Thanks: Gave 22, Got 10
Small home cinemas - opinions sought!
I am thinking about converting a small room in to a home cinema but I am seeking opinions on small room sizes.
The room I have is 1.9M wide by 3.4m in length x 2.1M high.
If you have a room of similar size can you post your thoughts regarding sound and general opinions?
I plan to use all of the equipment thats in my sig.
Panasonic Ax 100 projector, Arcam AVR300 , DV 79 , CD 82,
PMC DB1+ center,Quad 11L's,77 DS rears, SVS SB12 + sub
elliotjames is offline
Old 25-11-2007, 9:11 PM   #2 (permalink)
Miniholic's Avatar
Thanks: Gave 485, Got 363
Re: Small home cinemas - opinions sought!
My room isn't much bigger at 2.3m wide, 4.1m long, and 2.4m high.
Can't tell you how it sounds yet as its not finished, but should only be a few weeks.
Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, AE500 & NS830 VCR.
Carada Criterion 92" fixed screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is offline
elliotjames (25-11-2007)
Old 25-11-2007, 9:34 PM   #3 (permalink)
I am worried that its too narrow and i'd be overpowered with sound.
Mini fan eh ? I used to own a mk1 Cooper S full works replica a few years back great cars
Old 25-11-2007, 10:37 PM   #4 (permalink)
Lennyz's Avatar
Thanks: Gave 16, Got 9
I will be watching this thread as I have a room I am thinking about using as a dedicated one it is 2.4m wide X 4.1m long X 2.4m high.
It does seem a small room to convert but I have toyed with fitting a projector in our much bigger lounge and I can't decide whether to go for a smaller dedicated room or not.
The against points for the lounge outweigh the plus points in my mind as a dedicated room gives me more options for such as light control and decor as well as being able to use a cheaper fixed screen to leave on show rather than having to shell out for an electric and have to house it away neatly in the ceiling. I also don't think I could live with a projector hanging above the sofa. I know you can use an in ceiling lift but the cost for them is probably as much as or more than a projector.
My kit- Pioneer 433 mxe, NAD T760 receiver, M&K K series. (3 x K7, 2 x K4 ), Arcam DV88. Velodyne SPL1200 subwoofer. Pronto RU950 via rf
Lennyz is online now
Old 26-11-2007, 12:39 PM   #5 (permalink)
hmm sounds like the measurements of my completed dedicated cinema room 3mx2m ish
ill grab some details and pics for you to help you decide, but I think the size I have is just right, the projector isnt ceiling mounted either, and I have a monster 92" screen for the space... the sound system is not amazing at present, its on next years budget but ill do a more detailed review for you when I get back from work tonight, in case it helps anyone
VoodooK1ng is offline
Dr Force (26-11-2007)
Old 26-11-2007, 7:13 PM   #6 (permalink)
Ok room dimensions are 335cm long x 261cm wide x 236cm high
Kit is:
92" Saphire Parklane series 16:9 Matt white screen
Sanyo PLV-Z5 projector (screen and proj both purchased from cvsmedia)
*Temporary* Sony DAV S300 5.1 hooked up with S-Video cable as thats all ive got on that souce kit
Sub is turned right down and still gives off the desired bass effect. Doesnt echo in the room so sound for me is perfect. My bro has got a really decent sound and source setup which I will eventually upgrade to similar items at some point, to make use of the HD projector and HDMI connections.
I was contemplating the same thing with dedicated room and lounge room. Lounge is 457cm x 317cm so a fair bit bigger. But the layout an use of it wouldnt really fit a cinema installation, and would be more work really. So I decided to keep the two seperate in the end.
a Few pics, room still needs some paint on the wall im just deciding on some dark colours to complement its use ie dedicated cinema room. The window is blacked out with some fabric I found lying about, pitch black during the day so cinema experience all day round:
Projector and mount using an old TV bracket, wasnt much space at the back and the damn window was in the way to do anything easily.
The projector screen, please excuse all the crap at the bottom, its a makeshift "cabinet" actually part of a corner computer desk on its side
and the comfy seating at the other end of the room, was thinking on sofa, but when looking at the costs involved thought bean bag sofa would be better use of the space, and its very very comfy
example of the image quality taken with a 7mp camera
http://i216.photobucket.com/albums/c...g/DSC00519.jpg
Old 26-11-2007, 7:51 PM   #7 (permalink)
Thanks for info.My rooms only 1.9 so the extra 600cm or 2 ft makes all the difference if mine was that wide I wouldnt be too worried but at 1.9 its only just wide enough to fit my screen in.
Anyone else?
Old 26-11-2007, 9:27 PM   #8 (permalink)
Lennyz's Avatar
This is great!
I am now really coming round to the idea of small cinema room. I mean if you can use a room as a dedicated cinema room it has to be better really doesn't it? Making a lounge fit the bill will have to be something of a compromise in most cases. In a small room you can maximise screen size across the width and the sound system I would imagine could work really well toned down to suit closer listening.
Anyone else out there with a smaller room as a dedicated? any piccies...
cinemas, home, opinions, small, sought
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Anyone seen these before?? Opinions sought... tburfield AV Stands, Cabinets, Seating and Furniture 1 30-12-2006 1:06 AM
DIVX playble home cinemas nowonda Home Cinema DIY 13 05-11-2004 1:53 PM
Why do we have so much bass in the home compared to even the best cinemas? Stewart C Speakers 6 17-10-2001 7:08 AM
My home Cinemas on my web site jlcrawford DLP, LCD and D-ILA Projectors 14 31-07-2001 5:09 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
