AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 25-11-2007, 7:55 PM   #1 (permalink)
LED lighting
I see many people have LED lighting behind their tv etc, i like the look of it and i want some but dont know where to get them. i herd ikiea but i cant get to ikiea and they dont deliver where i live.i also want some to go in my shelves also.
anyideas on where to get them?
cheers!
dannywaugh1 is offline
Old 25-11-2007, 8:45 PM   #2 (permalink)
Thanks: Gave 2, Got 5
Re: LED lighting
I got the appollo home lighting kit from noodleman on these very boards. go and look in the home lighting power buy threads.
ark383 is offline
Old 25-11-2007, 9:39 PM   #3 (permalink)
hjl
Thanks: Gave 0, Got 2
Re: LED lighting
LED lighting is the future - but at the moment it's only really suitable for "decorative" purposes rather than providing useful light. A few suppliers can be found on Archisearch - http://www.archisearch.co.uk/
hjl is offline
Old 25-11-2007, 10:09 PM   #4 (permalink)
Thanks: Gave 11, Got 3
Re: LED lighting
Have you considered using Duralight?
I'm sure that's what I will end up using.
piers-uk is online now
Old 28-11-2007, 1:09 PM   #5 (permalink)
Thanks: Gave 3, Got 1
Re: LED lighting
LED's are currently only good for decorative lighting as the output from them is no where near as good as a conventional fillament lamp. This is unliekly to change either as the wavelength of light from an LED means that the light coul dbecome damaging to the eye if the LED were any brighter.
The main issue is that whilst they look nice and bright when you look directly at them, the light falls off quite quickly.
Last edited by inzaman; 28-11-2007 at 1:16 PM. Reason: Removed the parts that break forum rule no. 7, please read the forum rules before posting - Thanks.
Goochie is offline
Old 01-12-2007, 11:18 AM   #6 (permalink)
hjl
Re: LED lighting
I agree that the blue spectrum light that current white LEDs emit is thought to be a problem in that it can be damaging to the eyes. However there is some work going on to get round the problem - e.g. http://www.vanderbilt.edu/news/releases?id=22603
hjl is offline
Old 03-12-2007, 11:47 PM   #7 (permalink)
Re: LED lighting
There are some LED lights that are on the market that are bright enough to be used as main, task lighting, LEDs are now produced and used in street lighting, 10Watt LEDs are used in MR16 and GU10 products.
Some example of recent products and applications used at home include my kitchen. Its small at 3x3m but I run just 6 GU10 LED Bulbs, no fluro, no halogen, no other source and only use 15W of power.
I have used flexible RGB colour changing LED mounted to the underside of my father-in-laws kitchen base units, wired to a wireless RGB controller to give single colour or fade.
Security light size/style fixtures which use LEDs to flood the front of house for haloween, using just 9 watts.
Single LEDs mounted in to the side of wooden stairs to give just enough light to see the treads without having any lights on, all using around 1/4 watt.
Cuttable LED strips used to back light display cabinets.
Full RGB DMX controllable MR16 and floor lights with RGB colour changing pelmets and shelving.
There are more design possibilities using LEDs than standard lighting.
This Christmas we shall also be using just LED lighting for our decorations with an plan to use less than 50% than previous years.
If you have any questions about LEDs, configuring, using, purchasing, sourcing, recommendation then I would be more than pleased to offer advice.
Simon
TLLCUK is offline
Old 05-12-2007, 6:16 PM   #8 (permalink)
Thanks: Gave 5, Got 46
Re: LED lighting
Hi Simon, can I ask where you got the flexible RGB leds from for the under cupboard lighting and how much they cost as I am looking for a similar solution
Streetrod is offline
Old 05-12-2007, 6:59 PM   #9 (permalink)
albriscoe's Avatar
Thanks: Gave 307, Got 265
Re: LED lighting
Simon
Hi Simon
could you possibly show us any photo`s of your areas lit with LED`s please mainly to see what the ambience is like without using "normal" lights
thanks in advance
Allan
Click to see my selfbuild/basement cinema
Onkyo TX-NR 905 M&K`s SW150 fronts SW95s rears Sub M&K MX125 Mk 11 SIM Grand Theatre PJ 118" 16.9 fixed screen HTPC Asus AMD2 6000+ CPU LG BD/HD player 4gb DDR2 Ram 5t/b h/drives Panny TH-50PX70 / TH-42PX70 Samsung LE40A756/BD-P 1500 Humax Freesat HD
albriscoe is online now
led, lighting
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Lighting - TV/Stereo/Wall/Shelf Ambiant Lighting for your setup! Noodleman Home Automation and Lighting Power Buys 542 15-09-2008 3:59 PM
Which lighting control system & blub type for living area lighting flying low Home Automation, Lighting, Security, Heating and Cooling 8 28-10-2007 7:40 PM
Lighting help Holy_Pilgrim Home Automation, Lighting, Security, Heating and Cooling 0 04-12-2006 9:14 PM
lighting for my HT....... bad ass Home Automation, Lighting, Security, Heating and Cooling 0 24-01-2006 8:11 PM
Lighting Crazy Paul Plasma Televisions 2 24-07-2005 8:31 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
