AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 25-11-2007, 1:41 PM   #1 (permalink)
Cables behind working gas fire?
Hi I need some help and advise.
Im looking for a way to run some cables to the other side of the room for my living room set up.
Going throught the ceiling and under the floor are out of the question.
Would it be possible to run cable through the chimney behind the fire place?
I would idealy drill about 10inches up from the floor and run through. Obviously the heat issue is to take into consideration, but what if i ran through some metal type of trunking or something? I have no idea if this possible or not, wether the heat generated would really be an issue as the fire would only be on sometimes in the evening for a maximum of 3 hours.
There would be no electric cables just AV (Hdmi, speaker wire and the sky HD).
Would this be possible?
Any help or advise would be greatly appreciated. I have attached a plan just so you get a rough idea of what Im trying to achieve.
Thanks in Advance.
Fusion5a is online now
Old 25-11-2007, 2:18 PM   #2 (permalink)
Thanks: Gave 1, Got 11
Re: Cables behind working gas fire?
Don't go there
Putting holes in what is effectively the flue could cause so many problems (some fatal) That it would take a day to explain it all.
Take the cables a different route . End of..........
I never apologise. I'm sorry but it's just the way I am
hufartd is offline
Old 25-11-2007, 2:22 PM   #3 (permalink)
Thanks: Gave 2, Got 13
I had the same problem and ran the cables under the fire, sandwiched between the floor and the hearth.That way there was no heat issue!
Dude a llama is offline
Old 25-11-2007, 2:22 PM   #4 (permalink)
Well I Live for my AV but wud I die for it? No chance.
I take it that was what you meant by being fatal?
Oh well back to the drawing board I guess. Shame really but there is no way of setting up the system that I want other than having to run wires to the other end of the room.
Thanks anyway.
Old 25-11-2007, 2:33 PM   #5 (permalink)
sbowler's Avatar
Thanks: Gave 119, Got 430
Remove skirting boards, chisle out a channel, glue skirtings back on.
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is online now
Old 25-11-2007, 2:35 PM   #6 (permalink)
I thought of that but the skirts stop at the fireplace as there it is an old cast iron fireplace that sits on slate slabs.
Old 25-11-2007, 3:05 PM   #7 (permalink)
Hi Dude,
Can you explain a bit more about how you did this "sandwiched between the floor and the hearth" and what tools you used pleased?
Old 26-11-2007, 8:06 AM   #8 (permalink)
Super Moderator
Ian J's Avatar
Thanks: Gave 694, Got 1,506
Transferring to Home Cinema DIY forum
Ian
Opinions expressed by myself are not necessarily those of AV Forums
Ian J is offline
cables, fire, gas, working
Refbacks are On
Thread Thread Starter Forum Replies Last Post
For sale: speaker cables (various) / 3m scart cables / 0.5m L/R Audio Cables piknik Archive : Completed Business and Expired Threads 34 22-10-2006 9:12 PM
Is it really OK to mount a Plasma above a working gas fire? sean_numark Home Cinema DIY 3 28-02-2006 11:30 PM
Microsoft IR Control Cables not working philbury Computer Systems 2 08-07-2005 6:01 AM
Component cables, unable to get working bazzah Interconnects, Speaker Cables and Switches 6 07-03-2005 1:46 PM
Kef PSW2010 - working ... not working ... working .. not working balders Subwoofers 5 22-02-2005 2:26 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
