AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 24-11-2007, 1:53 PM   #1 (permalink)
Solid Wall and Scart Cables....
Hi everyone,
First time poster, long time visitor for advice!!
I am about to Wall mount my TX32LXD70, and am going to put my Sky Box and DVD Player on the opposite side of the (solid) wall in the space which once upon a time was my understairs cupboard and is now an open space with a coat rack etc (so ventilation isnt a problem!).
There is power there already, so literally all I have to do is run the TV Power Cable and two scarts through and a small bit of coax for the magic eye to the sky box.(No coax for the aerial, i dont use terrestrial through the aerial)
So here lies my question. How the hell do I get the scarts through? Is the only way to make the cables up myself? I have seen these detachable plug jobs, but they are compsite only, not RGB.
Anyone got any wise words to help me out!?!
Thanks in advance
Paul
hammondo is offline
Old 24-11-2007, 5:45 PM   #2 (permalink)
SeanT's Avatar
Thanks: Gave 62, Got 215
Re: Solid Wall and Scart Cables....
Make a bigger hole!!! Get a scart lead where you can take the plugs apart so that the bit you need to fit through the hole is smaller in the first place - or you can solder them up if you want but it isn't much fun....
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
SeanT is offline
Old 24-11-2007, 5:50 PM   #3 (permalink)
Didn't realise that you can get the plugs apart on some cables, mine don't do that!! Is it fairly common that the plugs dismantle, or have I just got crap cables?
I appreciate the bigger hole argument, but drilling a cable size hole is one thing, a scart size hole is quite another!!! Don't want my bedroom to colapse into my living room just because i was trying to make my cables tidy!!
Thanks for your advice
hammondo is offline
Old 24-11-2007, 8:18 PM   #4 (permalink)
SeanT's Avatar
It actually tends to be the cheaper cables that you can take apart, leaving only some soldered connections onto the internal metal bit, more expensive ones tend to be sealed, but it is possible to find decent ones that come apart and as such go quite small - if you are running four cables through a hole this hole won't be far off what you need to get one of these through
SeanT is offline
Old 24-11-2007, 8:32 PM   #5 (permalink)
Blimey, maybe my cables arent as poor as i thought!! I've been looking and some cables appear to unscrew at the plug. Would these be the ones that dismantle? If so, fully wired gold ones would be a reasonably good bet?
Thanks again.
Paul
hammondo is offline
Old 24-11-2007, 10:37 PM   #6 (permalink)
Thanks: Gave 292, Got 207
The quickest, and easiest bet would be to drill a hole, just hire a Core Drill for the day, it should cost you less than £10 and it would be done in 5 mins.... HEY PRESTO... job done...... you could always buy a brush faceplate to tidy the hole !!
Deano
dbs2 is offline
Old 25-11-2007, 8:03 AM   #7 (permalink)
Deano
I'd love to do that, but it is a solid wall so I don't want to be making holes any bigger than I have to. Like I said above, I don't want my bedroom falling in my living room just for the sake of a couple of tidy cables!
hammondo is offline
Old 25-11-2007, 8:44 AM   #8 (permalink)
SeanT's Avatar
It's a solid wall, I wouldn't panic too much, unless you are making a really really big hole, then you'd need a lintel or an RSJ - how do you think windows get put in?
SeanT is offline
Old 25-11-2007, 9:20 AM   #9 (permalink)
Down to B&Q for a core drill it is then.....
hammondo is offline
Old 26-11-2007, 8:58 AM   #10 (permalink)
MarkP80's Avatar
Thanks: Gave 69, Got 60
Your other alternative is of course a hammer and chisel. The scart plug isn't massive, so you can chisel the edge of a brick and the mortar. It's a bit more labour intensive than a core drill of course!
You might find it easiest to get scart leads through with the cable "straight-on" as opposed to being at right angles to the plug, if you know what I mean.
MarkP
My Cinema and the Bar!
MarkP80 is offline
cables, scart, solid, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
running a scart cable through a wall & other cables? ian_w Interconnects, Speaker Cables and Switches 1 20-08-2007 10:36 PM
How easy is it to wall mount a PX60 to a solid wall? Rookies Plasma Televisions 1 24-10-2006 8:51 PM
Cat 5 or Cat 6 / Stranded or Solid? What's best for speaker cables Tyler Durden Interconnects, Speaker Cables and Switches 3 24-08-2006 4:36 PM
Scart, HDMI cables for inner wall setup. ivan1912 HDMI Cables and Switches 3 18-06-2006 11:56 PM
RGB only scart, heavy duty LCD wall mount, DVI cables SeanT Archive : Completed Business and Expired Threads 38 23-08-2005 1:08 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
