AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 24-11-2007, 11:32 AM   #1 (permalink)
dUnKle's Avatar
Thanks: Gave 102, Got 109
I want to hang my LCD on the wall - how ?
Have a 37" Sharpe LCD screen to which we want to hang on an (internal) wall
Are there any tips or guides ?
The wall itself does not seem hollow, but then again it does not seem very hard or heavy either - not sure if its a stud wall or not
What do I need to do to ensure its safe and secure and also whats a recommended height ?
CHeers
dUnKle is offline
Old 24-11-2007, 11:50 AM   #2 (permalink)
Sofa-loafer's Avatar
Thanks: Gave 11, Got 17
Re: I want to hang my LCD on the wall - how ?
If its a new style house the wall will more than likely be timber/stud wall. Tap it with your knuckles, if it sounds hollow then it probably is...
Wall mounts are easy to choose, most websites will tell you which mount suits your screen.
Concerning height, somewhere in the middle, between your ceiling and floor. If you have reclining seat then you can go a little higher - but I'd say don't put the top of your screen above 4 feet or around 50"... whatever you feel comfortable with. My thread explains bits that may help you, but the best advice I can give is to browse through all the threads in this DIY section.
Good luck...
Media Wall Experiment (on a budget...) - http://www.avforums.com/forums/home-cinema-diy/608570-chimney-breast-flue-removal-wall-mounted-lcd-future-htpc.html
Sofa-loafer is offline
Old 24-11-2007, 1:06 PM   #3 (permalink)
dUnKle's Avatar
The sound of the wall is strange
It certainly does not feel as hollow and echoy as the wall dividing the bedroom but it does not feel as hard and solid as the outside wall
dUnKle is offline
Old 24-11-2007, 1:13 PM   #4 (permalink)
Thanks: Gave 11, Got 61
It may be dot n dabbed. This is common on houses about 20-30 years old ( mine is 30 years old). Basically they dot plaster onto a breeze block wall and the push the plaster on. This forms a small hollow between the palsterboard and the breeze block.
You 'could' try drilling a hole and seeing what you get
My build
cybrey is offline
Old 24-11-2007, 10:25 PM   #5 (permalink)
Thanks: Gave 292, Got 207
If you can't work it out by drilling, you could always work out the place to wan't to hang it, then cut a 100mm x 100mm hole in the wall with a stanley knife which you would cover with the bracket, you would defently work out what the wall is, or more fun for us, you could post a pic of the sample hole to us on here, so we can all peer into it
Deano
dbs2 is offline
hang, lcd, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
How to wall hang the pdp 436xde Albertoo Plasma Televisions 16 23-05-2006 3:37 PM
Can I hang Panasonic PW7 on a plasterboard wall ? jeegnesh Home Cinema DIY 30 29-12-2005 6:01 PM
Can I hang my plasma on my wall ? mehullakhani Plasma Televisions 4 20-07-2005 2:57 PM
Can you hang DLP TV's on the wall? Stampax Rear Projection Televisions 6 12-06-2005 2:10 PM
Can you wall hang a PV500? alliwant Plasma Televisions 6 25-04-2005 8:11 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
