AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 22-11-2007, 10:33 AM   #1 (permalink)
Ivor the Engine's Avatar
Thanks: Gave 3, Got 3
Skirting board
Does anyone have any good ideas about a skirting board which allows for me to run cables behind it without interferring with the walls?
All ideas welcomed.
Ivor the Engine is offline
Old 22-11-2007, 10:35 AM   #2 (permalink)
mossym's Avatar
Thanks: Gave 21, Got 140
Re: Skirting board
2 options i though of
standard skirting, get a router and route a channel along the back of the skirting. screw onto the wall as opposed to nailing and you'll be able to pop on and off as required.
or, what i went with
small trunking along the top of the skirting, painted the same color as the walls. can't be seen unless you look for it, check out my sig below for examples, or i can take more if you need
My Home Cinema Room
My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 4* B&W 603, 2* B&W 602.5,B&W LCR600, Hsu STF-3. XBOX360 + HDDVD. HTPC for Blu-ray + HD Satellite
mossym is offline
Old 22-11-2007, 11:28 PM   #3 (permalink)
Thanks: Gave 2, Got 1
Re: Skirting board
I have just seen this in Maplin which looks like it goes on top of your exisiting skirting.
Something I am going to be looking into soon too
hth
ewan
ewangto is offline
Old 22-11-2007, 11:36 PM   #4 (permalink)
Sofa-loafer's Avatar
Thanks: Gave 11, Got 17
Re: Skirting board
G'day Ivor... if your talking about reversable skirting then you may be able to use one of the Ovolo reversable's.
Either side of a reversable skirting can be placed against the wall. Using the Ovolo side against the wall may give you enough room. I guess it all depends upon how many cables your using and the diameter of the cable.
http://www.swiftwood.co.uk/arch_dstops_skirtings.html
Media Wall Experiment (on a budget...) - http://www.avforums.com/forums/home-cinema-diy/608570-chimney-breast-flue-removal-wall-mounted-lcd-future-htpc.html
Sofa-loafer is offline
Old 23-11-2007, 8:52 AM   #5 (permalink)
Thanks: Gave 3, Got 1
Re: Skirting board
Have a look at this site
http://www.kentplastics.com/SkirtingBoards.html
They have skirting trunking and also they have a skirting board cover system (this is what we bought) It fits over your existing skirting board and provides a nice recess for cables. Never needs painting and is bash proof.
thegavsters is offline
Old 27-11-2007, 2:03 PM   #6 (permalink)
Re: Skirting board
Thanks all.
Old 27-11-2007, 11:57 PM   #7 (permalink)
Thanks: Gave 22, Got 14
Re: Skirting board
You have either http://www.tlc-direct.co.uk/Main_Ind...ing_Pvc_Index/
or http://www.gwsupplies.co.uk/electric...g+trunking.htm or even http://www.findtheneedle.co.uk/produ...g-trunking.asp
I have been told you can have wood finish also.
cheap option: I have seen in my local dealer shop that they have put a normal skirting board that they have push 5cm out and put a piece of wood on top to close the gap on top. it works quite well too.
Hope this helps.
Ongoing HC Room build
Arcam AVR 350|Front: MA RS8|Rear: MA RS1|Center:MA RSLCR
Display: Panasonic PTAE-700E| 60GB PS3 PREMIUM| the rest to come
Geoxis is offline
Old 28-11-2007, 9:10 AM   #8 (permalink)
Thanks: Gave 27, Got 18
Re: Skirting board
You could always put down some electrical conduit first and then sit your normal skirting on top of that.....when the carpets laid it'll hide most of the conduit.
-Simon-
AV Setup- Sony Bravia KDL-52W3000 - Sony Strda1200ES - Sony PS3 40gb - SKY HD - Wharfedale Diamond 9.1 AV Home Cinema Speakers - WireWorld & QED Cables -
Camera Setup - Canon EOS 40D+Grip - Canon 24-70 L - Gitzo Tripod & Head - Pocket Wizards - Gitzo GT2931 - Gitzo GH1780QR - My Flickr Page
SAuchterlonie is offline
board, skirting
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Speaker Mounting on Skirting Board?? jkharmer Speakers 20 26-01-2007 9:34 PM
Speaker wire & Skirting Board question Shooter1 Interconnects, Speaker Cables and Switches 4 20-04-2006 7:35 PM
Anybody got skirting board heating? Bernard Barnett General Chat 18 11-04-2006 3:36 PM
removable skirting board? cochese Home Cinema DIY 10 06-10-2005 12:41 PM
Cabling around skirting board into a bay window? Carlos13 Interconnects, Speaker Cables and Switches 4 17-06-2005 5:40 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
