AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 21-11-2007, 10:01 PM   #1 (permalink)
Thanks: Gave 24, Got 14
Bt Scocket And ASDL Combined
Hi i currently have a bt phone scocket in my room like this one
http://www.home-networking-online.co...UK-WHT-101.jpg
i then have a micro filter connect then a spliter with 2 cables goin to goin to my modem and sky Hd box this all looks a bit of a mess and i was hoping i could replace it with a scocket like this
http://www.home-networking-online.co...lter_1254.html
Will this do the job ? if not would someone be kind enough to recomend something ?
the_m0ney is offline
Old 21-11-2007, 10:26 PM   #2 (permalink)
Thanks: Gave 48, Got 49
Re: Bt Scocket And ASDL Combined
You will need to open the phone socket in your bedroom and check if it is a Master or Slave unit (master has capacitor in it) , I would of guessed it is a Slave. The link you provided (http://www.home-networking-online.co...lter_1254.html) is for a Master socket.
If its a Slave then try this http://www.adslnation.com/phpapps/ca...products_id=95
The XTF-68/85 sockets are designed to replace existing extension sockets or for installing new extensions. The XTF sockets should not be used to replace the official BT NTE-5 master socket, as replacing your master socket is not permitted under the terms of your contract with BT. If you want to replace your master socket then please use one of our XTE-2005 faceplates that replace the front of the master socket leaving the BT wiring untouched.
plasmad00d is offline
Old 21-11-2007, 11:32 PM   #3 (permalink)
Miniholic's Avatar
Thanks: Gave 485, Got 363
Originally Posted by plasmad00d View Post
If it is a slave socket, try your local DIY centre. I got a filtered slave from Focus for under £5.
Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, AE500 & NS830 VCR.
Carada Criterion 92" fixed screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is online now
Old 21-11-2007, 11:34 PM   #4 (permalink)
Im sure it is a master socket but how can i tell for sure ?
Old 21-11-2007, 11:56 PM   #5 (permalink)
Master
Slave
Note the capacitor is the main missing component in the Slave unit
Old 22-11-2007, 1:28 AM   #6 (permalink)
it dosnt look like either of those it looks like this
so will any from the asdl nation work ?
Old 22-11-2007, 1:28 PM   #7 (permalink)
N42
Thanks: Gave 32, Got 8
TLC do them too, I've just stuck one on my shopping list
http://www.tlc-direct.co.uk/Products/GPADSLS.html
TH50PF10, DVDO Iscan HD+, Eltax DV-254, Denon 2106, Mordaunt Short Premiere, SVS PB10-ISD, Humax PVR 8000T, Harmony 885, PS2.
N42 is offline
Old 22-11-2007, 5:03 PM   #8 (permalink)
now i have posted the type of scocket i have could someone please recomend what scocket i should get
Old 22-11-2007, 6:48 PM   #9 (permalink)
Thanks: Gave 2, Got 42
The link you show in post 1 is what you need. Although that is expensive, you should be able to get one for about £10.00
http://www.amazon.co.uk/NTE5-compati.../dp/B000IBIIPK
On post six, this unit just replaces the piece that is shown on the left hand side of the picture.
leaky5 is offline
Old 22-11-2007, 7:04 PM   #10 (permalink)
thanks very much leaky5
Old 24-11-2007, 10:20 AM   #11 (permalink)
as Leaky5 say's, you were defo correct in post 1
the socket you are showing is the main BT one that takes the drop cable from the street and all extensions are wired back from this
it's the 'new' style, that allows the bottom half to be removed for customers wiring, but the main BT only cables remain 'hidden' from view
also has the test socket behind it
inder is offline
Old 24-11-2007, 2:47 PM   #12 (permalink)
Thanks: Gave 6, Got 1
If you want the BT Faceplate it's a NTE2000 can be had on egay amongst other places.
spid is offline
Old 24-11-2007, 5:39 PM   #13 (permalink)
Thanks: Gave 0, Got 2
I've changed my main socket to one of these. Makes such a difference to broadband speeds as all the rubbish is filtered out. Easily worth the money
Woody26 is offline
Old 24-11-2007, 5:44 PM   #14 (permalink)
SeanT's Avatar
Thanks: Gave 62, Got 215
Why would it matter if you replaced a slave socket with a master exactly? A master socket is a universal replacement, no need to cut the capacitor out - but for the NTE5A you need to fit an NTE2000 frontplate or similar - make sure you don't mess with the master socket, or at least if you do don't do it in a detectable way (ie. in a way that obviously isn't BT engineer compliant)
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
SeanT is online now
Old 24-11-2007, 8:47 PM   #15 (permalink)
Never quite worked out what the capacitor does. I was in my house for 3 years ( with Broadband ) before I found out that the external BT wiring was punched down onto the IDC'c in the removable part of the master socket, i.e. bypassing the capacitor. It was changed back to how it should have been, but made no difference to the BB speed.
leaky5 is offline
asdl, combined, scocket
Refbacks are On
Thread Thread Starter Forum Replies Last Post
ASDL Router with NTL jonathanmusto Virgin Media 1 26-01-2007 11:10 PM
asdl modem bobdixon Computer Systems 2 24-01-2006 2:07 AM
ASDL Modem/Router Rasczak Networking 14 30-11-2005 12:10 PM
Bt Voyager asdl modem2091 non Bt? bwizz Computer Systems 0 27-11-2005 6:22 AM
Belkin ASDL Modem Wireless Router Woes Rasczak Networking 3 14-08-2005 3:10 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
