Ok, i will explain the reason behind this thread. (then i will get on with what you actually want to read/see!!!
About five years a go, i decided i wanted floating shelves to hold my AV equipment.
I reasoned, that since the new TV was going on the wall so was the rest!
This was where the trouble started...
The fancy Ikea types were for effect only, and were neither big enough or strong enough to hold more that a tea bag...
Since i had already installed some in the corner recesses, i wanted the same look.
I soon realised i would have to make my own.
I always over enigineer any thing i make, and my new shelves were no different!
I sandwiched three 18mm sheets of MDF together then drilled and fitted them with high tensile steel bolts.
These where then resin set into the entire brick depth, and glue bonded to the plaster...
I posted some pics here, in the "get your Plasma out for the lads" thread.
Ever since, i have had a steady stream of emails/Pms asking where i bought my shelves.
Each message has been answered, and each person has been guided how to do it as well etc.
However, i recently needed more shelf space (PS3/360 etc) and didn't fancy having to make the original shelves again.
They were actually quite heavy in themselves, so i didn't think scaling them up would be a good idea!
I did have concerns about how the hell to remove the old shelves, but twenty minutes with a sledge hammer/grinder soon sorted that!
Here's a few pics of the old shelves. (i will started the new shelves in the next post etc)
