AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 18-11-2007, 9:55 AM   #1 (permalink)
rmcdonald's Avatar
Thanks: Gave 7, Got 0
Acoustic Insulation for Floors MLV vs green glue
I know the vexxed subject of acoustic insulation has been trashed out here and elsewhere but my question is quite specific.
I'm converting 3rd floor into a Home Cinema and I'm trying to achieve a decent level of acoustic insulation.
My intention is that Mass Loaded Vinyl (MLV) will be laid over timber joists and existing thermal insulation. T&G chipboard flooring will then be laid on top, cf. the last image @ http://www.customaudiodesigns.co.uk/...ofing/emem.htm
I intend using "green glue" between 2 layers of Plasterboard on the walls & ceilings.
My question:
In terms of acoustic insulation for floors which is better:
"green glue" between 2 layers of T&G chipboard flooring
-or-
MLV then one layer T&G chipboard flooring ?
Help appreciated
Thanks.
rmcdonald is offline
Old 18-11-2007, 11:12 AM   #2 (permalink)
Lizard's Avatar
Thanks: Gave 120, Got 45
Re: Acoustic Insulation for Floors MLV vs green glue
Originally Posted by rmcdonald View Post
My question:
-or-
No expert but i would have thought MLV would be better as thats whats it's designed for, were as Green Glue is designed for walls.
However if you are doing this to stop the sound leaking to the room below, then why not just fit a false ceiling in that room with insulation/air gap? I would have thought it would cost the same or less and should give far better results than either of the two methods mentioned.
Always acknowledge a fault. This will throw those in authority off their guard and give you an opportunity to commit more. - Mark Twain
Lizard is offline
Old 18-11-2007, 12:06 PM   #3 (permalink)
rmcdonald's Avatar
Thanks for your reply Lizard.
Originally Posted by Lizard View Post
...if you are doing this to stop the sound leaking to the room below, then why not just fit a false ceiling in that room with insulation/air gap?
Fair point but there are multiple rooms below. Whatever I do will have to be from top down.
acoustic, floors, glue, green, insulation, mlv
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Green glue questions... clarky78 Room Acoustics, Audio and Video Calibration 7 17-07-2007 7:23 PM
Green Glue pure_geordie Home Cinema DIY 4 11-08-2006 7:49 PM
Anyone Using Green Glue lnewey6 Home Cinema DIY 28 11-07-2006 4:17 PM
Green Glue Londondecca Room Acoustics, Audio and Video Calibration 4 21-02-2006 8:14 PM
Green Glue Killahertz Room Acoustics, Audio and Video Calibration 1 07-12-2005 8:53 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
