AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 16-11-2007, 6:36 PM   #1 (permalink)
mavice's Avatar
Thanks: Gave 12, Got 20
Lightbulb Mavice's Underground Home Cinema
Its been a long road, but I have just decided the principle use for my 'underground' room in my new build
After checking progress on the build today, it is just begging to be a dedicated HC room (with maybe a double use as music listening room and studio)
below is a shot I took today.
The room is 3.4m wide and I will be able to sit about 4 - 4.5m back, a bit close but never mind.
The back wall is solid concrete, 300mm thick with earth behind it to ceiling height.
I think it will absorb sound quite well with the right wall coverings.
There will be no windows.
a bit boring to look at a wall of concrete at the moment but I will try to post the
ongoing photos as the room develops and of course the finished room
Panny PHD9 & AX100 for the big events on SkyHD
Denon 3805 for the film, Audiolab 8000CD & 8000S for the pure musik
Quad Lite system & Sub
And a MMUK screen in silver
mavice is online now
Old 16-11-2007, 6:52 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 119, Got 430
Re: Mavice's Underground Home Cinema
Looking forward to seeing the build, looks like an ideal blanck canvas. No annoying the neighbours with the sound levels.
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is online now
Old 16-11-2007, 8:09 PM   #3 (permalink)
albriscoe's Avatar
Thanks: Gave 307, Got 265
Hi Mavice
it seems to ring a bell mate somewhere this new build basement cinema room, dejavu even
Hope all goes well with the project my friend, please keep us all informed with plenty of pics
cheers and good luck
Allan
Click to see my selfbuild/basement cinema
Onkyo TX-NR 905 M&K`s SW150 fronts SW95s rears Sub M&K MX125 Mk 11 SIM Grand Theatre PJ 118" 16.9 fixed screen HTPC Asus AMD2 6000+ CPU LG BD/HD player 4gb DDR2 Ram 5t/b h/drives Panny TH-50PX70 / TH-42PX70 Samsung LE40A756/BD-P 1500 Humax Freesat HD
albriscoe is online now
Old 16-11-2007, 9:34 PM   #4 (permalink)
mavice's Avatar
Originally Posted by albriscoe View Post
Hi Mavice
Allan
Hi alan
now I have to spend the next 3 hours reading your 17 page thread to pick up any tips....thanks.
forgot to mention, my build is in Spain so very different to yours in construction techniques and materials. - hopefully the end result will be as impressive as yours is looking.
may be some time before an image is actually projected onto that cement....maybe maņana
Simon
Old 17-11-2007, 9:14 AM   #5 (permalink)
Lizard's Avatar
Thanks: Gave 120, Got 45
The dream HC room with out a doubt.
I'm sure you have already got this covered, but how are you planning to insulate the room? Not for sound proofing but for warmth (having lived in a few basements i know first hand how cold they can get).
Always acknowledge a fault. This will throw those in authority off their guard and give you an opportunity to commit more. - Mark Twain
Lizard is offline
Old 17-11-2007, 10:05 AM   #6 (permalink)
albriscoe's Avatar
Originally Posted by mavice View Post
Hi alan
Hi Simon
we looked at new builds in Almerima (Almeria) last year and when I looked at yours I thought of them (dejavu again). where abouts is yours if you don`t mind me asking
cheers Allan
Old 17-11-2007, 10:19 AM   #7 (permalink)
mavice's Avatar
Hi Lizard
I am not too sure on how they insulate the concrete retaining walls. For the normal brick walls, they build the outside wall in air brick, spray on 30mm of expanding foam over the entire surface, leave an air gap of 50mm or so and build an internal wall in air brick.
I suspect the reason for cold basements is primarily damp issues. Something that is not such a problem here.
The back of the concrete walls are sprayed with a bitumin type black finish before the ground is filled up to it for damp proofing (not that much is needed) .I am guessing that they will spray the concrete direct with foam and then build an internal wall with cavity but they may just board direct to the concrete.
It might be a good idea for me to ask them to board with insulated plaster board as a minimum though or put some sheets of polystyrene behind the wall before backfilling
Thanks for reminding me to think about it -.
Old 17-11-2007, 10:37 AM   #8 (permalink)
mavice's Avatar
Hi Simon
cheers Allan
Hi alan
Ours is in Granada so not too far from Almeria.
Convenient now the flights are direct from East Midlands, its only about 2 hours 20 min flight.
It looks a bit like an NCP carpark at the moment but should be 'closed' by the new year.
The HC room will be the one bottom left. The far end will be underground and the near end level to the garden due to the slope on the plot.
It is also under the garage so less risk of noise polution
OK - back to choosing a boiler - far less interesting than choosing the next PJ or amp.
Old 17-11-2007, 10:38 AM   #9 (permalink)
Lizard's Avatar
I would assume that you are getting them dot and dab plasterboard onto the concrete walls to finish them of anyhow, so to dot and dab insulated plasterboard instead does make sense (you will need to check what thickness/grade they use though as their quite a choice).
how are you planning to finish the ceiling? I don't no if you can use dot and dab or not on ceilings and you cant screw the plasterboard to concrete (well not ecomincally anyhow!) The trouble is this is were you lose the bulk of the heat.
Your right about damp in cellars causing cold, but its also because they dont get any sunlight to heat them, and the last thing you want to have to do is run the heat all the time to make the room useable.
PS not trying to be bossy only seeking to insure you dont slip up like i did!
Lizard is offline
Old 17-11-2007, 10:56 AM   #10 (permalink)
mavice's Avatar
Its funny, I had all the same questions
I am quite familiar with the materials and techniques available UK side but feel completely out of my depth in Spain. for example, plaster board is still a relatively new thing in Spain and not widely used.
I believe, but dont quote me, that the walls will be boards dabbed with adhesive and the ceilings are suspended (galv strip system) as this is where much of the services pipes and electric conduits are installed, so naturally there is an air gap insulation.
The garage may not be heated so again your suggestion is useful - I need to think about the ceiling insulation too.
That said, the bigger problem here is keeping rooms cool. The winter is really only 2 months long but the summer can be 45 degrees. Even with no heating, the room would be useable for 9 - 10 months of the year.
for example, yesterday was 19 degrees here.
today it was 2 degrees at the plot at 9am so its getting colder at night but by this afternoon, it will be about 16 - 18 degrees.
cheers
Old 17-11-2007, 11:52 AM   #11 (permalink)
Lizard's Avatar
Fair play Simon, you seem to have everything covered.
If it helps, dont forget insulation works both ways, not only does it keep heat in but it will also stop heat from the outside entering into the room to.
Lizard is offline
Old 17-11-2007, 1:35 PM   #12 (permalink)
Thanks: Gave 11, Got 61
Going to be an impressive house Good luck with the build.
My build
cybrey is offline
Old 16-12-2007, 4:33 PM   #13 (permalink)
mavice's Avatar
The build has a few more walls now and the roof is mostly done.
The HC room unfortunately, will be one of the last formed as they seem to work from top floor down. - no pics of it closed yet.
attached is a pic of how walls are built in southern spain to provide insulation - it shows the srayed on foam on the outer skin and the inner wall part built
Old 19-12-2007, 10:14 PM   #14 (permalink)
mavice's Avatar
So we had the back of the HC room built with an arch
That way, it will look more like a 'Bat Cave'
Old 11-07-2008, 4:27 PM   #15 (permalink)
mavice's Avatar
Well ...6 months on and the build takes most of our time
We are at plastering stage and windows & doors go in this month (after plastering)
The concrete wall of the room were 'lined' with air bricks to contain conduits, sockets etc. No insulation was needed according to are architect as the ground behind the wall will insulate well.
Ceilings are formed in the traditional spanish way with 1m square, tongue n groove cement/plaster boards and then skimmed. Quite interesting as the boards are hung from stringy rope made from grass and cement adhesive to stick it to the concrete ceilings and boards. The result looks as good as the UK system of plasterboard once skimmed.
Looks like it will be 2009 before the room can be used for any kind of HC though as still loads to do elsewhere
