Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 22-10-2007, 12:40 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Black Nickel Wall Plates AV + Ethernet
I'm in the middle of renovating my whole house and plan to install a HT system / structured network
I plan to fit black nickel sockets and switches all over the house and i like the ones from screwfix
http://www.screwfix.com/cats/A431881...ee-Low-Profile
The only trouble is they dont do a matching ethernet faceplate
Anyone got any ideas ? Or could I modify a blank plate for ethernet use?
sentinal is offline   Reply With Quote
Old 22-10-2007, 2:06 PM   #2 (permalink)
Thanks: Gave 7, Got 11
Re: Black Nickel Wall Plates AV + Ethernet
Have a look here:
https://www.1stopelectrics.com/category/567/1/
They do an Iridium black finish which is close to black nikel.
You can add different modules into the data grid face plates
jefff is offline   Reply With Quote
sentinal (22-10-2007)
Old 22-10-2007, 2:11 PM   #3 (permalink)
thanks, they do a good range there, might lookat the differnet choice that they have
have you purchased some yourself? was wondering what the look/quality of them was like
cheers
Old 22-10-2007, 3:36 PM   #4 (permalink)
I've used both the screwless ones and the flat plate (with screws). IMO the quality isn't as good as the grabtree / MK Electric range (MK do a similiar range with loads of modules but cost more!)
Never the less, for the price there ok.
Old 22-10-2007, 3:40 PM   #5 (permalink)
thanks again!!
have you used the Iridium black finish ones? do they look good themselves?
Old 22-10-2007, 3:49 PM   #6 (permalink)
I use the Iridium data grid plates in our cinema room. One set has 2 x RJ45, BNC,Coax, the other I've modded with a brush strip behind it and is used as a cable outlet.
Old 22-10-2007, 3:50 PM   #7 (permalink)
Thanks: Gave 36, Got 28
I bought the screwfix flat plate black nickel range. I have to go elsewhere for the ethernet ones. I used a local electrical wholesaler who got some "GET" flatplates in black nickel for me. They are an excact match for colour and appearance.
as5606 is offline   Reply With Quote
Old 22-10-2007, 3:54 PM   #8 (permalink)
you mean these ???
http://sparkyselectrical.co.uk/item-...get_blank.html
but as a data grid?
Old 22-10-2007, 7:15 PM   #9 (permalink)
Miniholic's Avatar
Thanks: Gave 516, Got 386
Also have a look at these. BG electricals screwless range is a close match for the Crabtree stuff.
I've got some on order myself as the do diplexed and triplexed RF sockets that crabtree don't cover in their range.
Sony HW10, Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, NS830 VCR.
Carada Criterion 92" screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is online now   Reply With Quote
Old 24-10-2007, 8:47 PM   #10 (permalink)
thanks, can you order them from BG electricals direct?
cheers
Old 24-10-2007, 10:13 PM   #11 (permalink)
Miniholic's Avatar
Don't know to be honest, might have to give them a call as I've been waiting a couple of weeks for mine order through a local supplier.
black, ethernet, nickel, plates, wall
