Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 16-10-2007, 8:45 AM   #1 (permalink)
Question Component distribution via Cat5-what about audio?
Hi folks
I'm currently looking at distributing a Sky Hd componenet output via a Keene
CHDD8A 1:8 distribution amp.
I am converting to Cat5 with 5x Muxlab comp/cat5 baluns. My problem is what to do about the audio! There is 1 pair spare in the cat5 & I think I'm correct in assuming I can send digital audio from the Sky Hd (converted optical/co-ax), but there will be no digital input at the tv end.
Do I need to convert from digital audio to analogue & am I going to suffer any degradation of sound quality.
I only have 1 Cat5 cable to each Tv.
yagiman is offline   Reply With Quote
Old 16-10-2007, 10:00 PM   #2 (permalink)
dunks517's Avatar
Thanks: Gave 360, Got 283
Re: Component distribution via Cat5-what about audio?
Hi there, Have you already purchased your component baluns? If not then have a look at these baluns, they have component & digital audio (coax)connections:
http://www.lektropacks.com/view_item...1&&category=30
The only problem will be the audio, you may have to put an amp in with the TV (even if its only a stereo one it will be better than the tv speakers)
Assorted gear: Panny 42TH PX70, B&W Speakers, Kef HTB 2 Sub, Linn Diskreet speakers, multiroom Sky+ HD, PS3, Tosh EP30 HDDVD, Acer iDea 500 HTPC, Sennheiser HDR-120s, network gubbins, Xbox360s, Wii, Harmony 525, 360 & One.
My Av-centric home
dunks517 is offline   Reply With Quote
Old 17-10-2007, 9:25 PM   #3 (permalink)
thanks dunks
Desperately need to find either a tv with a digital audio input or a digital audio to analogue converter.
struggling
audio, cat5what, component, distribution
