Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-10-2007, 4:29 PM   #1 (permalink)
DMT
Thanks: Gave 7, Got 12
Rockwool advise please
Garage is now studded and so I need insulation; I have seen 140KG/M RW6 Rockwool (and equivalents) but this is very expensive. I have also read that the RW3 is just as good for sound proofing despite being a lower gsm, can anyone please offer some advice.
Thanks.
Living Room- Epson TW500 PJ Pioneer 503MXE Plasma Pio 868 DVD Pio AX4 Amp 6 x B&W VM1 Rel Q150E Sub JS Scart-Comp Sky+ Xbox360 Home Cinema (Garage)- MA GR20 MA GR10 MA GRLCR MA GRFX Pioneer AX10Ai 3 x Musical Fidelity M250 Monoblocks SVS PB12+ SMS-1 Carada 118" JVC HD1 360 PS3 EP35
DMT is offline   Reply With Quote
Old 10-10-2007, 6:11 PM   #2 (permalink)
Re: Rockwool advise please
Thanks.
Hi DMT,
Yes you are quite right that lower densities also provide useful acoustic performance, the British Gypsum white book offers extremely helpful guidance on differing wall constructs, and the basic rules of thumb are as follows:
The mass lines of the wall provide the greatest effect to sound insulation, particularly at low frequency.
The greater the size of the void the greater the performance
Isolating the timbers from the underlying structure also improves performance.
Allowing an air void is also assistive.
Therefore assuming you are using a mass-line of plasterboard, twin skin with staggered joints is best (each sheet offset by 400mm for instance) using 100mm studs with the studwork isolated from the brick/block work and the void filled with a 50mm mineral wool absorbent, then all that remains is seal all joints and the perimiter for leakage.
Note that these comments relate to insulation only and not to absorption within the enternal condition (room).
A company with very helpful info is Siderise Insulation - www.siderise.co.uk - their 'solution' pages have alot of useful pointers.
Regards JG
johngray is offline   Reply With Quote
Old 12-10-2007, 12:20 PM   #3 (permalink)
DMT
JG,
Thanks for the reply.
I have a single bricked garage followed by a 2" airgap, hardboard and wood studding with lafarge 12.5mm db check board to go on after insulation.
I think I am going with Rockwool 67MM acoustic partition slab, pack of 9 £44.42 from Travis Perkins. I am taking the project on from here, the previous work was done by a builder but with no previous acoustic knowledge.
Material Thickness Frequency (Hz)
(mm) 125 250 500 1K 2K 4K
Acoustic Partition Slab 67 0.30 0.70 1.00 1.00 1.00 1.00
Thanks.
advise, rockwool
