06-10-2007, 6:27 AM
#1 (permalink)
| | Member
Thanks: Gave 44, Got 56 | Dedicated room on a budget
Background:
I have been considering upgrading my TV in my living room for some time. I currently use the TV with a HTPC for all my TV, movies and computing. The TV is a JVC 56" HD-ILA 720p. The TV is good but for computing I was finding the resolution too restrictive so wanted a 1080p set. The only TV I could find that I was almost happy with was the new 52" samsung LCD. It costs £2300 and for that I would have got a smaller TV that is 1080p but appart from that would not be much different to the JVC. This just seemed like a lot of money for not much improvement so decided rather than that I would convert my top bedroom to a dedicated room using my original budget for the TV (£2500).
__________________ Play room: Z5, Onkyo 605, Q acoustics 1000, Wii, Xbox, Ps3, HTPC, SkyHD, URC810 Living room: JVC 56 HD-ILA, VSX-AX2AS-S , Kef 3000, HTPC, Sky+, Nevo SL Server: Windows Home server. Gamer tag: ToonDoom |
06-10-2007, 6:29 AM
#2 (permalink)
| | Member
Thanks: Gave 44, Got 56 | Re: Dedicated room on a budget
The room:
The room was not much used and in a huge mess
Notice the lovely head board
06-10-2007, 6:32 AM
#3 (permalink)
| | Member
06-10-2007, 6:38 AM
#4 (permalink)
| | Member
Equipement:
For £2500 I needed projector, amp, speakers, HTPC. So far I have everything excpet the HTPC.
Projector - Sanyo Z5
£630 http://www.1staudiovisual.co.uk/cata...or-p-1783.html
Was a choice between this and the panasonic. Was concerned with the flickering issue with the panasonic so went with the Z5.
AMP/speakers
£900 - including cables
Onkyo TX-SR605
Q Acoustics 1000 speakers http://www.creative-audio.co.uk/HCS_ONK605_Q1000.htm
06-10-2007, 6:47 AM
#5 (permalink)
| | Member
The room with the equipement in it. Cabling for speakers and projector go into loft then back down in wall.
Got some ikea seats. Cheap but comfortable.
06-10-2007, 6:52 AM
#6 (permalink)
| | Member
Painted the walls. Steel gray 4 and 1.
06-10-2007, 6:54 AM
#7 (permalink)
| | Member
Moved my office furniture up from what was my office. The unit to the left used to be wider. I modified this myself to fit the space exactly. All the AV equipement will go there.
06-10-2007, 6:59 AM
#8 (permalink)
| | Member
That is the progress so far. Someone is coming round today to fit lan cables from the server to the room.
07-10-2007, 7:59 AM
#9 (permalink)
| | Member
Thanks: Gave 14, Got 6 | Re: Dedicated room on a budget
Looks good so far, I quite like the grey  I hope you don't mind asking but does the LAN wiring cost much and will any electrician do it or do you need someone specific?
07-10-2007, 2:52 PM
#10 (permalink)
| | Eminent Member
Thanks: Gave 1,138, Got 7,576 | Re: Dedicated room on a budget Quote:
Notice the lovely head board | What's wrong with the head board!
Looks like your rooms gonna be cool,nice one!
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS PC13 Ultra  PS3 Slim, Oppo BDP-83, XE1, Logitech 1000 remote, wildlife pond in back garden and six fish tanks in the house.
Show me Potato Salad! |
07-10-2007, 2:59 PM
#11 (permalink)
| | Senior Member
Thanks: Gave 516, Got 386 | Re: Dedicated room on a budget
Great looking room mate.
Have you got a painted screen or is the full wall the same shade? Can't really tell from the photo.
__________________ Sony HW10, Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, NS830 VCR. Carada Criterion 92" screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000. My DVD’s The Miniplex Skip to the end... |
07-10-2007, 4:12 PM
#12 (permalink)
| | Member
Thanks: Gave 44, Got 56 | Re: Dedicated room on a budget Quote:
Originally Posted by wavefront Looks good so far, I quite like the grey  I hope you don't mind asking but does the LAN wiring cost much and will any electrician do it or do you need someone specific? | I paid £100 for two runs of cat5e. One run from living room to garage. One from garage to third floor bedroom via loft. http://www.vispec.co.uk/ did the cabling. Very nice job including testing the quality of the line. Ran the cable through the loft down in the wall to a face plate. Nice bloke too; definelty recommended if you are local to them.
I guess an electrician would do it but you would probably have to test the line your self. The bit of kit he brought to test the line costs £1000
07-10-2007, 4:14 PM
#13 (permalink)
| | Member
Originally Posted by wavefront Looks good so far, I quite like the grey  | Out of the dark colours this was my favourite. I was painting it as a slight compromise to get a dark room but now it is up I think it looks quite cool. I will just have to call the room the "submarine"
07-10-2007, 4:16 PM
#14 (permalink)
| | Member
Originally Posted by Miniholic Great looking room mate.
Have you got a painted screen or is the full wall the same shade? Can't really tell from the photo. |
I have painted the screen with a matt white (4 coats!). I will see how it goes and may get some screen goo eventually. I have some wood that needs a couple extra coats of black paint. What that is done I will put it up as a border.
On the subject of the screen do not judge the picture quality on these shots. I have made no attempt to capture how good the image is.
07-10-2007, 4:28 PM
#15 (permalink)
| | Member
The "screen" with the projector off:
The office area including home made rack. The gap is for my HTPC (after I spec, order and build it). The big silver PC is my server(windows home server) and will be hidden in a cupboard in anouther room:
