I am having problems locating any decent installer in the western algarve for my new build home that is under construction as we speak. I fear therefore that I am going to have to do most of it myself. I am about 5 weeks from the electrician going in and hence need to be ready to advise what I need.
The project is essentially a basement that will be a cinema room i.e. projector and screen and probably a 5.1 speaker set up. I would also like to pipe music into each room that could be controlled separately in each room and I would like to have a large wall mounted plasma or LCD in the living room.
I would like to have sky available in the basement and lounge.
I would also like to have broadband access in some of the rooms.
Firstly, I would like to know if I am correct in thinking that I need to run 2 video cables to and from each room? Speaker cable is obviously required in the cinema room and lounge but what cable do I need to run to each room for the individual music to be piped? I would like to source this music from a central server containing my cd collection what is the best way of achieving this.
I will also need to run cat 5e for the broadband network and phone but should I run a 3rd for later expansion purposes.
What do I need to do in order to receive the sky by satellite is there anything special required to get that into the cinema room and lounge.
Presumably I will need a distribution panel of some kind is there anything else I will need?
Once the video cables reach the rooms concerned what type of equipment do I need to connect the tvs to i.e. what wall panels and how do I connect component etc to this?
Ooh I am getting confused now!!! I am trying to get this project clear in my head and to keep it simple enough that it will all work without having to get anyone in.
I`m sure someone will come to your aid mate soon, can we have a photo or 2 of where you are in the Algarve please and your new build of course. My cinema is in the basement so you might want to take a look for inspiration
why didn`t I build in the Algarve does anybody know???
good luck
Allan
PS. if you put us up for a couple of weeks I`ll come and do it
