03-10-2007, 8:18 PM
#1 (permalink)
| | Member
Thanks: Gave 3, Got 0 | Help for Hiding wireing
Later this month when the pay check arrives in i intend to redo the bedroom - i.e new paint , furniture and chair (Lazy boy  ) i want to wall mount my 42" tv and i will have the equipment below on a small table below - i was looking for some advice on how to hide the cable , i have heard of trunking however i havnt a clue how it is done and i want a clean and proffesional looking job - what do i do - also with easy acces to add new cables in if i ever want to add to the AV equipment
who can help all ideas welcome , please no silly answers looking for genuine answers
thanks in advance
04-10-2007, 7:38 AM
#2 (permalink)
| | Member
Thanks: Gave 92, Got 77 | Re: Help for Hiding wireing
Hi Scott2802,
What sort of wall are you mounting it on? - solid brick, stud partition, or what?
This has quite an impact on how easy it is to hide the cables and therefore on what technique best suits your application.
Regards,
MarkP
04-10-2007, 12:42 PM
#3 (permalink)
| | Member
Thanks: Gave 3, Got 0 | Re: Help for Hiding wireing
Thanks for you help
its a solid concrete wall - when i intend to redo the room i will get a plasterer in and i will paint over the plaster.
just want to wall mount the tv and hide the wireing - what are my options with this type of wall
thanks
04-10-2007, 1:05 PM
#4 (permalink)
| | Senior Member
Thanks: Gave 519, Got 163 | Re: Help for Hiding wireing
If you're getting a plasterer in anyway, I'd definitely chase the cables into the wall (be sure to put them inside some appropriate tubing). The plasterer can then skim over & Bob's yer Monkhouse  .
04-10-2007, 4:25 PM
#5 (permalink)
| | Member
Thanks: Gave 3, Got 0 | Re: Help for Hiding wireing Quote:
Originally Posted by Shockabuku If you're getting a plasterer in anyway, I'd definitely chase the cables into the wall (be sure to put them inside some appropriate tubing). The plasterer can then skim over & Bob's yer Monkhouse  . | will that not leave a part in the wall that is sticking out - as in a visible bulge lol
04-10-2007, 4:29 PM
#6 (permalink)
| | Senior Member
Only if you don't go deep enough  . Really, it's easy to do, and you won't even know the cable's there once the plasterer has done his work.
04-10-2007, 4:30 PM
#7 (permalink)
| | Member
so does he need to cut into the wall to stop a bulge - is this then permanant - how do i add new cables if the situation ever needs be |
04-10-2007, 4:30 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 519, Got 163 | Re: Help for Hiding wireing Here's a thread with some good info.
04-10-2007, 4:37 PM
#9 (permalink)
| | Member
thanks thats really helpful - is this then permanant - how do i add new cables if the situation ever needs be
04-10-2007, 4:49 PM
#10 (permalink)
| | Senior Member
Well, if you used tubing of a decent diameter, you could pull through new cables when required...maybe...I'm thinking small cables, not scarts! Best option is to run enough wires for the foreseeable.
