Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 30-09-2007, 9:19 PM   #1 (permalink)
JonnyAlpha's Avatar
Angry LCD TV STAND spares or modification
Strange One and probably in the wrong area but I finally bought the first part of my HTPC the case!!!
I got a Black ANTEC FUSION from GHS Tech in London £120.00 got it home unpacked it (very nice) slid it into the space in my stand and IT DOES NOT FIT.
Why did you not measure it I hear you say well I did.
I measured the height no problem with that, I even measured the width, again OK, but I forgot to measure the depth AGGGHHHH!!!
You see my stand is one of those classy three tier Dark Glass Stands with the chrome legs, I bought it with the TV from COMET or CURRY`s can`t remember.
It is wider at the front and tapers at the back, this I did not account for.
The only option I can think of to alleviate my dillema is to DOCTOR the rear supports of the stands I need to lose about 1.5 cm from each.
They are round tubes that slide onto a threaded bar so I could maybe hack a chunk out of each.
Anyone know where I could get some spares??
The stand has no name just comes in a cardboard box with STAND SUITABLE FOR LCD TV SKU 292923 Item Number KM-TS013M-K
Ta
JonnyAlpha is offline   Reply With Quote
Old 01-10-2007, 1:47 PM   #2 (permalink)
xxalxx's Avatar
Thanks: Gave 5, Got 2
Re: LCD TV STAND spares or modification
sounds like :
KENMARK TV stand - up to 32 inch
xxalxx is offline   Reply With Quote
Old 02-10-2007, 12:16 PM   #3 (permalink)
JonnyAlpha's Avatar
Originally Posted by xxalxx View Post
Thats exactly the baby!!
Now if only someone would offer up some spare legs so I can get chopping!!!
Another suggestion was to move the rear base supports (form the level that the HTPC will sit on) E.G. dismatle the stand and re-build but this time dont slide the rear legs that sit between the bottom and middle glass onto the threaded bar but sit them off to a flank.
Don`t know if the glass is weaker at this point though??
lcd, modification, spares, stand
