Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 26-09-2007, 11:24 AM   #1 (permalink)
Thanks: Gave 1, Got 0
my lounge with progress pix Now More pix
after lurking on this forum for a long time i finally decided to go for it
and mount my tv on a false was wall and i thought i would share my progress
with you guys.
Room before:
My 1st thought was to build a false chimney around where the fireplace is,(the dodgy coloured wall with ramdon white paint on was wallpapered which we have removed) but because the wooden floor is already laid the chimney breast would of had to come out as far as the hearth is to cover the hole in flooring, I (or the wife) didnt want this as we felt it would inpead to much into the
room.
i thought why not put a wall across this corner of the room:
I searched the forum to see if this had been done (without success) i really wanted to see and end result beforehand.
then i went through more thought about what the best layout would be and i finally deceded to bite the bullet and went for the corner option the following pix are my progress:
Height test for the screen:
Frame work built across the corner:
close up of tv bracket - i'm going for the recessed look hence the bracket being set back from the front of the wall
first hang of the tv to see what it was like:
then i built the frame work for the recess under the tv and put the 1st plasterboard up-the tv was put up afterwards i to check the cut out i made in the board
plasterboard completed with metal edging strip for the sharp edge and shelf in place in recess - this is removable so i can gain acess the plugs which will be underneath
More to follow!
red7jase is offline   Reply With Quote
Old 26-09-2007, 12:26 PM   #2 (permalink)
Franco50's Avatar
Thanks: Gave 34, Got 38
Re: my lounge with progress pix
Good on you mate. Glad to see someone attempt the corner option as I've thought about that route as well. Not all living rooms are ideal for the conventional 'TV-wall'. Keep up the good work and post lots of pics.
I take it you had to mitre cut the timber battens for the front face of the construction?
Franco50 is offline   Reply With Quote
Old 26-09-2007, 3:33 PM   #3 (permalink)
elootos's Avatar
Thanks: Gave 221, Got 193
I too thought about having a corner install and yours looks like it'll work well in the room. After all, if you think about the space that a floor unit takes up then it makes no odds as to blanking out one corner. Also as your shelf is removable it looks like there's plenty of room to have equipment underneath it hidden away, which is always a nice option to have.
elootos is offline   Reply With Quote
Old 26-09-2007, 7:27 PM   #4 (permalink)
looking forward to the finished article, it looks very neat & smart already, and thats just th creative stages!!!
good luck!
Eddie
itsmeeddie is offline   Reply With Quote
Old 26-09-2007, 10:46 PM   #5 (permalink)
Thanks: Gave 24, Got 25
Looking good mate, keep the pics coming.
Scifi Lord is offline   Reply With Quote
Old 27-09-2007, 3:17 PM   #6 (permalink)
Gordie's Avatar
Thanks: Gave 123, Got 69
Well done Jase
Looks like it's going to be a belter when done. Can't wait for the pictures.
My Home Cinema
PSN: newcarron
Gordie is offline   Reply With Quote
Old 28-09-2007, 8:47 AM   #7 (permalink)
Thanks: Gave 198, Got 137
This is a great job and definitely some inspiration for those with room that are suited to having the TV in the corner.
As everyone else has said, keep the pics coming!!
Dedicated Home Cinema Room
Max Payne is offline   Reply With Quote
Old 30-09-2007, 4:44 PM   #8 (permalink)
Done more work and this is were i am at now
1st hang of the tv - the wire to the left is sky cable prior to me doing it properly roung the outside wall and back in behind the false wall
this is the test of of the lights (ikea) behind the screen and in the recess and the sky wire sorted.
wall plastered
close up of tv and recess plastered
just the decoration to go now more to follow
Old 16-10-2007, 9:50 AM   #9 (permalink)
Franco50's Avatar
Looks good mate - don't forget some pics of the finished product!
Old 16-10-2007, 10:05 AM   #10 (permalink)
eireann10's Avatar
Thanks: Gave 151, Got 68
looks real good red, been looking for an corner design like this for ages.
can you tell me though, where have you got your power outlets, phone line (if you have one) and tv etc
think i need to build a hidden compartment below the AV compartment for the power sockets etc.
and what type of lights have you behind the TV?
eireann10 is offline   Reply With Quote
Old 16-10-2007, 11:48 AM   #11 (permalink)
eireann10's Avatar
red, do you have any measurements i could use.
i am more than likley goin to go ahead and use a fair bit of your design for my own room, just a few mods maybe.
Old 16-10-2007, 12:58 PM   #12 (permalink)
jagdeepp's Avatar
Thanks: Gave 174, Got 100
Interesting thread and idea. Looking forward to seeing the final pics. Hope you removed the Plasma before having it plastered..
Mind if i ask a question? Intrigued by your framework. I note that you put the initial frame in first then put battens in to fill it out. Were the battens connected to the main frame by countersunk screws or did you nail them in at an angle? Is it all very sturdy?
Looking real good. As suggested by Elootas it may be a good idea to try and throw some of the uglier equipment in behind the framework and put in an ir. eye for communication. Where are you planning to store your equipment?
Keep the pics coming.
My Set up: Sony Panny PT-AX100 HD Projector, 2.2 metre HCSV electric screen, Arcam AVR350 amp, HTPC's with 1 TB, Monitor Audio RS6 5.0, BK Monolith, Nintendo Wii, Snazio 1310, Xbox 360,
My Home Cinema Lounge & Home makeover
jagdeepp is offline   Reply With Quote
Old 16-10-2007, 1:03 PM   #13 (permalink)
lone ranger's Avatar
Thanks: Gave 0, Got 38
like this, very cool looking.
lone ranger is offline   Reply With Quote
Old 16-10-2007, 1:18 PM   #14 (permalink)
mason's Avatar
Thanks: Gave 40, Got 59
this is looking great.
i would love the corner unit system but the only place i have to put it (for optimum viewing purposes) has a window too close by.
great work
If you want it bad enough... you'll fight for it!!
mason is offline   Reply With Quote
Old 17-10-2007, 2:57 PM   #15 (permalink)
right guys thanks for your comments the decorating is almost done here are some more pix (i will post some more words later when i have more time but here are a few pix to be going on with
i will be back later with more words
lounge, pix, progress
