Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Old 29-05-2007, 10:02 PM   #1 (permalink)
Thanks: Gave 12, Got 2
Cables through outside wall? New install...
I'm planning on mounting my Tosh 42X3030 over a hole-in-the-wall fire place at about 1.1m above floor level.
As it is an outside wall I thought it would be easiest to drill through (avoiding the chimney), run the cables in conduit and then back in behind the component cabinet.
Has anyone who has tried this got any tips?
What cables should I allow for? (2xHDMI, 2xScart?, +power)
How do you get a big scart plug through a small hole?!
Is it worth using fancy socket plates?
I'll post a couple of pics later...
TIA
Toshiba 42X3030:Sony 5.1 amp & speakers:Sky HD:Samsung LE32R86WDX:Sony 20KLD2020U
VX Foxy is offline   Reply With Quote
Old 01-06-2007, 10:26 AM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 97, Got 1,360
Re: Cables through outside wall? New install...
an age old question with no prefect solution, best bed is avoid scart if possible
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
VX Foxy (05-06-2007)
Old 03-06-2007, 7:58 AM   #3 (permalink)
Thanks: Gave 44, Got 22
If you look at post #224 in this Home Cinema Construction: day by day diary with pics. you can see how an adaptor is being used to solve the chunky scart lead issue.
Not sure if you'll lose quality over a chunky scart cable tho - you'll have to experiment.
z
zpos is offline   Reply With Quote
Old 05-06-2007, 10:51 PM   #4 (permalink)
Thanks chaps. I think I have an idea to avoid going through the wall or chasing out my lovely new plaster, and that is to run a 'floating' shelf (concealed brackets) just above the TV and across the full width of the room - when I post some pics it will make more sense. I can then hide the cables in conduit above the shelf which should be just above eye level so hopefully will look fine...I promise to post pics soon :D
cables, wall
Copyright © 2000-2010 M2N E. & O. E.
