Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 25-05-2007, 8:19 AM   #1 (permalink)
Conspicuous Member
Thanks: Gave 141, Got 586
how do I inset speaker grill material in cupboard doors?
Its been recommended that I have my L/R front speaker further apart in my setup. I do move them out when using the projector, but that means leaving those doors open. I don't mind that but it was suggested I'll get better imaging leaving them further apart even when watching TV. To do that means being discreet.
I could get some white material (tights or something similar), but how would I go about getting that inset into the doors? It would need to be a really neat finish, so is it better to get someone to do it? They are IKEA doors so I guess they are particleboard? Gloss white fronts though so that might be difficult to cut/get a good clean line on. Assuming a hole can be cut, any tips on finishing off? Ideally the material would be attached flush with the front, but not sure how best to do that.
How big would you recommend for the holes? the speakers are fairly small but I think a small hole would look odd. I was thinking something like 1/3 the width/height of the door, in the center?
The doors are about £25 each, so I'd probably buy 2 more and get those done so I don't risk the currently installed ones.
Pic of setup below - the doors in question are the ones immediately to the left/right of the speakers.
richard plumb is offline   Reply With Quote
Old 25-05-2007, 8:42 AM   #2 (permalink)
Thanks: Gave 34, Got 61
Re: how do I inset speaker grill material in cupboard doors?
have you considered mounting them on the ceiling instead and pointing down towards your seating position - it looks like it'd be very difficult to achieve what you're suggesting - but for the sake of £50 it might be worth trying - whatever material you use it's likely to look out of place with the gloss finish on the rest...
if you go this route try this:
http://cgi.ebay.co.uk/Speaker-Grill-...QQcmdZViewItem
adam4478 is offline   Reply With Quote
richard plumb (25-05-2007)
Old 25-05-2007, 8:46 AM   #3 (permalink)
also - you'll tend to get shadowing behind the cloth. i'd suggest that cutting a hole which leaves a 10cm border around the edge of each door will give a more uniform look once covered. simpy stretch the fabric and use a decent staple gun to attach to the rear of the door.
Old 25-05-2007, 10:20 AM   #4 (permalink)
Kenny Glasgow's Avatar
Thanks: Gave 51, Got 207
You can get acoustically transparent cloth from Maplins, for around £5 per metre
Kenny Glasgow is online now   Reply With Quote
Old 25-05-2007, 12:33 PM   #5 (permalink)
Thanks: Gave 110, Got 108
i would look at the maplins option too, that cloth is quite good, there are places that you can buy material that is used on acoustic panels..
mattym is offline   Reply With Quote
Old 25-05-2007, 2:39 PM   #6 (permalink)
Conspicuous Member
thanks. But wouldn't it look better if I (somehow) tried to get the cloth flush with the front of the unit? Stapling to the back would be simple but then leave it indented. Plus when the units are chopped there would be wooden sides (although I guess could be painted easily)
Old 25-05-2007, 2:53 PM   #7 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
what you do mate is this have the doors off and take to a chippy get some frames made the same overall size as the door then either wrap speaker cloth arond the frame so cloth is on the front then refit hinges etc needs careful folding in the cornsers etc but could look awsome an upholsterer would/could do it for you if you dont fancy DIY with white cloth i think it would be stunning
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 25-05-2007, 5:22 PM   #8 (permalink)
Conspicuous Member
so you mean don't try and inset it, just make a door with the entire front made of cloth?
Old 25-05-2007, 5:25 PM   #9 (permalink)
Assured Advertiser
pretty much
Old 26-05-2007, 8:45 AM   #10 (permalink)
Thanks: Gave 14, Got 29
Why not cut out a hole, say 20x20cm or whatever size you want in the door. Then make a frame, like an artists canvas frame, out of wooden batons, say 19.9cm outer width, wrap the speaker cloth over that like you would a canvas print. Then slide that into the hole it'll just fit into, so that the canvas is flush with the front of the hole, then fix it with your preferred method (screws, no more nails, etc.)
That's how I'd do it, I think.
My Flickr
ab1385 is offline   Reply With Quote
richard plumb (27-05-2007)
Old 26-05-2007, 1:26 PM   #11 (permalink)
Thanks: Gave 18, Got 28
I guess that you want something like that shown in the picture of my ARCA units that I've attached.
Much like what ab1385 proposed, the speaker cloth is attached to a frame that then fits in a rebate behind the hole cut in the front of the doors.
John
johndon is offline   Reply With Quote
Old 27-05-2007, 5:01 PM   #12 (permalink)
Conspicuous Member
thanks ab1385, that sounds like a plan.
Thanks for the photo too, Johndon. Thats the sort of thing I'm looking for.
I don't know if it'll look weird having a gloss door with inset matt cloth. If so then Hornydragon's plan is a good one too.
I might try both and compare. Get a door from Ikea to play with and try both in situ for a while to see which works.
Old 27-05-2007, 10:01 PM   #13 (permalink)
Looking at the colour of the cloth, there is some similar cloths available on this page below. They usually bond well to wood using impact adhesive like Evo, but smelly stuff.
Simon at Nexxia is offline   Reply With Quote
cupboard, doors, grill, inset, material, speaker
