Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 24-05-2007, 11:25 AM   #1 (permalink)
nokiauk's Avatar
Thanks: Gave 56, Got 51
satellite wall plate
hi, i'm after a triple wall plate in white to provide a co-ax feed for freeview and twin f-type's for sky+.
can't find one anywhere. fm/dab not required.
nokiauk is offline   Reply With Quote
Old 24-05-2007, 3:04 PM   #2 (permalink)
Thanks: Gave 11, Got 62
Re: satellite wall plate
http://www.ekmpowershop2.com/ekmps/s...&productid=131
http://www.letsautomate.com/index.cfm?&Nav=Walloutlets&
http://www.nexxia.co.uk/Hi-Fi&TVacce...connectors.htm
Maybe something in one of those links.. I suspect the first one is the best.
cybrey is offline   Reply With Quote
Old 24-05-2007, 7:41 PM   #3 (permalink)
nokiauk's Avatar
cheers,
will give them a try.
thanks.
Old 25-05-2007, 6:35 PM   #4 (permalink)
Thanks: Gave 9, Got 37
dont know if its any good for you but depends on what you using for the rest of the house
i got around this with varilight by using the plates that take different modules this way could stick in 2 x sat and 1 x co-ax and 1 x BT
Hi-Def is offline   Reply With Quote
plate, satellite, wall
