Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Old 23-05-2007, 3:48 PM   #1 (permalink)
Cables behind walls
Hi there, Im new to the forum, just had a quick question. I think im in the right section!
Basically my family and I are moving into a new house in the next few months and the one we are keen on currently has a 5.1 system installed with the wiring all behind the walls. I'm pretty sure the previous owners will remove the system when they leave the house but I want to install our current 5.1 system (with the wiring hanging around the walls!) into the holes left by the previous system, just wondered how i would go about getting the cabling through the holes again.
Going to be fitting a projector in there as well in the future.
Thanks in advance for any help!
olliepack is offline   Reply With Quote
Old 23-05-2007, 4:45 PM   #2 (permalink)
Lufer's Avatar
Thanks: Gave 7, Got 13
Re: Cables behind walls
Hi and welcome. Are you sure they will remove all the cables? It may be more hassle than it is worth for them to do so. Its certainly asking your estate agent / solicitor the question and you may be able to come to some sort of deal if things are where you want them to be. If they definitely are removing the cables it is also worth asking if they would tie a draw string to the end of the cables before they pull them out and this way all you need to do is attach yours to the draw string and hey presto! job done...presuming there are not too many studs and corners to go through and around!
Otherwise it looks like you will have to resort to coat hangers and bits of wire.
TH42PH9; SkyHD; Onkyo TX-SR674E; B&W 602.5; LCR60; DS6; SVS PB10-NSD; Denon 1930; Cyrus Linkport; Wii
TH42PH9; SkyHD; Arcam AVR350; PMC DB1s (Front & Rear); PMC DB1MC+; Velodyne SPL800R; Cyrus Linkserver 250gb; Sony DVP-NS76
Lufer is offline   Reply With Quote
Old 23-05-2007, 4:46 PM   #3 (permalink)
Thanks: Gave 18, Got 28
Are they not likely to leave the speaker cable in the walls - it would probably be more hassle that it would be worth the remove it...
John
johndon is offline   Reply With Quote
Old 23-05-2007, 8:25 PM   #4 (permalink)
barty74's Avatar
Thanks: Gave 0, Got 5
i have seen plenty of cables installed into coving, then just dig it in to the wall where you want it....easy
Audio Visual Installer
barty74 is offline   Reply With Quote
cables, walls
