I'm considering relocating a horizontally mounted radiator as I want to put an LCD TV above it. scotia_steve74 posted this picture (thanks Steve!)
which got me thinking - would a vertical radiator work effectively (ie. heat the room) if it were located behind the door of my lounge as the door is mostly left propped open and would thus "hide" the radiator.
Failing that, I'll have to relocate the radiator behind a two seat sofa which may absorb much of the heat.
Also, how easy is it to relocate radiators? I have a floating floor in a ground floor flat built 10 years ago (1997) - I guess the pipes will need to be moved/extended, is this a "big" job with this type of floor?
Many thanks for any replies - I'm waiting for the Philips 37PF9732D TV and Denon AVR-4308ci to be released, all the while patiently making plans for my lounge!
