Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 10-05-2007, 1:17 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Distributing SKY
Would really appreciate some advice on this if possible. Currently have HD connected to main plasma via HDMI. Need to distribute the signal from the second sky box (multiroom) to other TV points around the house. The problem is that two of the other TVs are plasmas and from what I have read, distributing SKY pictures via a loftbox drastically reduces picture quality.
What is going to be the best way to distribute the SKY picture to the two plasmas in particular - not too worried about the other TV points.
Anyone have any advice in this area please?
Mike Robinson is offline   Reply With Quote
Old 30-05-2007, 3:34 PM   #2 (permalink)
Thanks: Gave 25, Got 7
Re: Distributing SKY
video signal over cat5? try milestone bluedelta products
MY CINEMA PROGRESS
Lounge: 42" LG Plasma - Denon AVR M330
Extension: Panasonic 50PX70 - Onkyo SR674E - Monitor Audio Radius In-Ceiling - BK XLS200 Sub
cwpaters is offline   Reply With Quote
Mike Robinson (30-05-2007)
Old 30-05-2007, 8:49 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Cat5 solution will allow you to run component video bu i reconmend running RF coax leads for freeview and control of HD box run 2 x cat5 and RF coax to each location
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 31-05-2007, 8:49 AM   #4 (permalink)
how do you get the sound over with the components?
MY CINEMA PROGRESS
Old 31-05-2007, 11:29 AM   #5 (permalink)
Assured Advertiser
you use the second cat5e for audio you can send component + Digital audio over 1 cat5e for stereo audio you need a seperate balun and another Cat5 cable which is why you run 2 cat5 and 2 Coaxes
distributing, sky
