Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 23-04-2007, 8:32 AM   #1 (permalink)
Thanks: Gave 1, Got 2
Laying Cables
Hi all,
hope this is the right forum for this. I'm currently setting up a sorrund sound system and I need to run 2 speaker cables to the rear satellite speakers behind the counch.
The cable needs to run along the floor beside the skirting and bay window from the receiver to the back of couch. Unfortunately I cannot remove the skirting or the wooden floor!!!
Can anyone advise on the neatest way to do this? I don't want to do any permemant damage to the floor, ie nailing, tacking or super gluing cables to the floor.
My initial plan was to use Pritt Stick and simply glue the cables to the floor. Pritt Stick is easy to wash off so no damage to the floor. Unfortunately it wasn't strong enough to hold the cable down. Another thought I had was to use double sided sellotape.
Can anyone advise on what they have done in the past?
Shane
shaneh is offline   Reply With Quote
Old 23-04-2007, 9:36 AM   #2 (permalink)
Re: Laying Cables
you can get a conduit that clips to the skirting board if that is any help?possibly something like this:
http://www.plasticsuppliers.co.uk/AmbassadorOgee.html
but I am sure i have seen better ones!
Mike
MikeCole is offline   Reply With Quote
Old 23-04-2007, 9:41 AM   #3 (permalink)
Re: Laying Cables
Cheers Mike,
unfortunately I've a big bay window in the middle so there is no skirting along this part. This is why I need to stick the cables to the flooring instead.
Shane
Old 23-04-2007, 11:09 AM   #4 (permalink)
Re: Laying Cables
Hi.
I had to lay my surround cables last weekend. You say you have a wooden floor.... are there any edging strips attached to the skirting board? If so, prise them off and run the cable around the edge of the floor as there should be a gap. I suppose you could get hold of some dark insulation tape, the closer match to the floor colour the better.
Lee.
Panasonic PX60. Alphason ADP3-96S. Denon 2107. Denon 1920S.
LeeG is offline   Reply With Quote
Old 23-04-2007, 11:37 AM   #5 (permalink)
Re: Laying Cables
Skirting is both glued and nailed to the wall (asked the builders) so no chance of this coming off!!! No gaps between the skirting and flooring to slip cable under either.
I think either double sided Sellotap or insulating tape is the way to go
Shane
cables, laying
