15-01-2007, 9:49 AM
#1
Thanks: Gave 2, Got 1
Help connecting an S-Video Socket, please help.
Hi, I've purchased a Keene S-Video & Socket Quick connect as I am trying to fit it high towards the ceiling so I can connect my projector, out of the way to it. Only thing is, I am not sure about how to wire it. I know it's a quick connect system and a wired system, but its going to be too tricky and tight to install it like that, much better wiring it in I think.
this is what I'm talking about :
http://img208.imageshack.us/img208/8373/dsc00889ss4.jpg
The connections I can see are "Y" on one side and "C" on the other. then I think it's Earth either side of those?
have a look at the back and see what I mean?:
http://img228.imageshack.us/img228/6061/dsc00888gn5.jpg
any ideas?
I've got an Svideo cable on order which I will cut the plug off when it comes.
thanks
15-01-2007, 1:59 PM
#2
Thanks: Gave 1, Got 71
Re: Help connecting an S-Video Socket, please help.
There's a diagram at Wikipedia: http://en.wikipedia.org/wiki/S-video#Connector_2 that shows the pin assignments. Hope this helps.
15-01-2007, 2:07 PM
#3
looks like the diagram will tell me what pin does what. I guess though when I cut the svideo cable, the cables I am hoping will be obvious as to which they are? or are they colour coded to you think?
23-01-2007, 11:29 AM
#4
ok, I've got my Svideo and it's cut now and all that is in there are two wires, red and white? see:
http://img209.imageshack.us/img209/9594/dsc009164uh.jpg
which would go where?
28-01-2007, 8:47 PM
#5
You might be able to unscrew the connector on the other end of the cable to see which cable goes to Y and which to C (ref the wikipedia link above).
28-01-2007, 11:18 PM
#6
Thanks: Gave 2, Got 11
strip the sheath of original connector you cut off (assuming you cut a factory lead) and see what pins the wires are connected to
29-01-2007, 7:54 AM
#7
it won't screw off at all, I've tried. oh well, a bit of trial and error I guess.
thanks
29-01-2007, 11:48 AM
#8
if you wire them the wrong way you should get is a B&W image
29-01-2007, 3:17 PM
#9
Thanks: Gave 71, Got 197
Each of the red and white wires should be a co-axial, i.e. you need to strip each further until you have the centre core and the screen.
If you have access to a test meter, "buzz out" the cable to find out which centre core is connected to pin 3 - luminance.
Connect that to the Y terminal. Connect its screen to the earth next to it.
Connect the other centre core to the C terminal. Connect its screen to the earth next to C.
In the absence of a test meter, I would guess that white is Y and red is C. Or as Scott suggests cut the plug open.
If that doesn't work, swap them round.
You're unlikely to get a B & W image if they're the wrong way round as there are no syncs on the chroma (you might get some sort of image). You would get B & W if the luminance was connected correctly but the chrominance wasn't.
regards
Brian
