Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 09-01-2007, 10:40 PM   #1 (permalink)
Chimney Breast
Has anyone actually removed part of the brickwork of there chimney breast to instal there Plasma so that it sits flush ?
I am aware that a few people have built out the chimney brest to get a similar effect but space is at a premium in this small room and the only option that I can think of is to remove some brickwork and fit a new beam to support the remainder of the breast that is left.
Any thoughts on this appreciated
CAS411 is offline   Reply With Quote
Old 10-01-2007, 7:44 AM   #2 (permalink)
Thanks: Gave 0, Got 4
Re: Chimney Breast
I've considered doing it in the past (not only for a plasma) but decided against it. I agree it would attain a great deal of additional space though.
It can be done if you retain the structural integrity of the remaining stack above. The width of the breast would determine whether it's feasable or not as you need sufficient sides of the chimney to remain to take the lintel and support it there upwards. The construction of the chimney is also a factor. Perhaps get advice from a reputable local builder on the feasibility and cost implications.
Bear in mind the mess, redecoration and flooring implications on top of the builders estimate. Also consider a power supply location and aerial point.
mr-gobby is offline   Reply With Quote
Old 10-01-2007, 4:29 PM   #3 (permalink)
Thanks: Gave 6, Got 9
Re: Chimney Breast
cas411, i inquired about this about 6 months ago, turned out for my chimney it could be done but would basically mean knocking it down and rebuilding it :/
I must admit, the flush look does look great though, my only concern with the flush look is what happens when you get another tele and the dimensions are different, could be a problem.
like gobby says get a reputable builder in as all houses and chimney breasts are different
APatel is offline   Reply With Quote
Old 01-05-2007, 4:48 PM   #4 (permalink)
Re: Chimney Breast
cas, check out my installation from the link in my signature.
Is that what you are looking for?
Lounge: LG 37LC2D, Harman Kardon AVR430, M&K K-5 / K-4 / KX-10, Pioneer DVR-630H, Harmony 885, HotlinkPro X12, Sony MXD-D3, Popcorn Hour A110. Check it out.
Kitchen: Panasonic TH-42PZ800B, Humax FOXSAT HD-R, Nintendo Wii.
Also: Creative Zen Vision:M
keyjade is offline   Reply With Quote
Old 01-05-2007, 6:47 PM   #5 (permalink)
Thanks: Gave 4, Got 8
Re: Chimney Breast
Do what i did I removed the complete breast and then support the rest, you will be supprised how much more room you have, total cost for me was £500 and it was well worth the money the room is so much larger and placing that all important av equipment is much better.
kingo is offline   Reply With Quote
breast, chimney
