All our walls have been replastered and painted recently.
I need to remove the wall bracket of one of the tvs and re-mount it with a new adjustable wall mount.
Can anyone recommend / advise me as to the best way to fill and smooth the 6 large holes I am going to have in my wall!
The new holes for the new bracket will be in the centre of the exisitng holes as the base for the bracket is much smaller so I need to make sure it is done properly and wont be noticeable as the area will be clearly visible.
Thanks.
Nickp.
