Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 03-01-2007, 5:05 PM   #1 (permalink)
Chimney Instal Pics
As it says really.........
Looking for some chimney Instal pics for inspiration please
Would ideally like to sink the plasma into the Chimney Brest so as it sits flush for a cleaner look but am not sure if this is possable yet , if not then I will mount the screen as per usual and shelf off the origional fire opening to at least store the AV equipment .
Any pics or Info appreciated
thanks
CAS411 is offline   Reply With Quote
Old 03-01-2007, 5:20 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 128, Got 466
Re: Chimney Instal Pics
Why not mount the plasma normaly on the chimney breast and then build out the wall so its flush with the plasma. A bit of 2 by 3 and some plasterboard, cover with lining paper and paint job done.
My flickr Pentax K20D/ K10D Sigma 10-20mm/Tamron 70-300mm/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is offline   Reply With Quote
Old 04-01-2007, 11:06 PM   #3 (permalink)
There are a few pics of my install in the link below
My install
Adamp81 is offline   Reply With Quote
chimney, instal, pics
