Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 30-12-2006, 7:07 PM   #1 (permalink)
Thanks: Gave 26, Got 22
Work in progress....finally mounting my kit on the wall **updated**
Recently joined the forums and tbh its kicked my *** into gear.
Today I finally mounted the surround speakers (its the Kefs 3005) and chased the cable into the wall (Its a new frame formed house so its plasterboard everywhere )
Because the wooden floor was already down I exited the cables on top of the skirting and ran them along behind the sofas in small conduit.This was the best option for me.
Obviously some final filling/sanding/painting to be done
http://img166.imageshack.us/img166/5...ture018lp4.jpg
http://img413.imageshack.us/img413/9...ture019qr4.jpg
http://img47.imageshack.us/img47/6459/picture020me2.jpg
here is my Sammy LE40R74 and the rest of the KEF's that I plan on mounting to the wall (just waiting on the mount to arrive).
And in the corner is my av reciever (as I am a noob to this I went for what seemed to me to be a reasonable model bang for buck) the Pioneer VSX1016 with the 6cd changer/player as well.
Im currently holding out for the Toshiba HD-XE1 dvd player ( but in the meantime been stocking up on some hd-dvd's )
http://img117.imageshack.us/img117/2...ture021xp8.jpg
http://img405.imageshack.us/img405/2...ture022rh1.jpg
For the mounting of the LCD and running in of the cables I have opted to attack it from the other side of the wall (the hallway) as any damage i do with be hidden by pictures
Any comments/advice/suggestions welcome
Cheers,
Ray
RJay is offline   Reply With Quote
Old 30-12-2006, 7:41 PM   #2 (permalink)
louishm's Avatar
Thanks: Gave 31, Got 54
Re: Work in progress....finally mounting my kit on the wall wall
looking good so far rjay, nice install of the rears.Take some nice progress pics when you come to do the complete install.
Just to go off topic but where did you get the marvel pics from.
paul
360 Gamertag:sparky2011. PS3 Gamertag:sparkypaul1.
Visit My Home Theatre
Visit My Re-Build
louishm is offline   Reply With Quote
Old 30-12-2006, 7:59 PM   #3 (permalink)
Hi Paul,
will post some progress pics, as for the marvel pics, they are actually canvas and came off ebay.If you search you can get them framed or unframed.the wolvie was framed the others I had done in a shop.
If you are interested search for the seller mainstreemartworks.
Very recommended or just do a search for pop art.
cheers,
Ray
btw noticed you on xbox live ..my gt is WeaponX68 ... maybe hook up some time
louishm (30-12-2006)
Old 31-12-2006, 9:18 AM   #4 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
Looks a good clean install
Visit my Home Cinema here
inzaman is offline   Reply With Quote
Old 31-12-2006, 9:43 AM   #5 (permalink)
lone ranger's Avatar
Thanks: Gave 0, Got 38
loking nice,whats that black thing in the bottom of your cabinet?
also great screen shot of your tv love seeing that scoreline..heeheehee
lone ranger is offline   Reply With Quote
Old 31-12-2006, 10:15 AM   #6 (permalink)
louishm's Avatar
its his centre speaker
Visit My Re-Build
Old 01-01-2007, 1:32 AM   #7 (permalink)
Thanks: Gave 34, Got 18
Is that a floor standing lamp: http://img47.imageshack.us/img47/6459/picture020me2.jpg
Any chance you could let me know where you got it from. I'm after something similar.
z
zpos is offline   Reply With Quote
Old 01-01-2007, 1:29 PM   #8 (permalink)
Yes its floor standing with a marble base.Got it for a reasonable price from ebay
Old 01-01-2007, 3:02 PM   #9 (permalink)
Thanks - Don't suppose you know what it's called so I can look it up?
z
Old 01-01-2007, 8:31 PM   #10 (permalink)
flos arco style (not original)
Old 01-01-2007, 9:06 PM   #11 (permalink)
Thanks for the prompt response. I'll see if I can find one on ebay.
z
Old 06-01-2007, 8:19 PM   #12 (permalink)
Well, finally got the wall mount today so thought...lets go for it!!
Luckily the mount spanned two studs so I didnt have to open up the plasterboard to fix a noggin
I used a dry lining double box for the cables to come through, unfortunately ,where I planned to put it I hit a noggin right bang in the middle
After a bit of drilling and notching it fitted.At least there were no others between that and the bottom
so after trimming a blank plate this is what it looked like behind the tv...
And after the tv is fitted...
The power cord came out with the other cables behind the tv but it was in conduit upto the point of entry...below it came out in its own box.....
I have brought them out at the bottom like that as I havent decided on where my av rack or even some sork of unit (like the one shown next) is going.
The finsihed product so far........next job is to mount the front,left and right speakers with cables concealed...but for the moment..its saturday night and im having a drink
please....comments,criticism welcome
Finally got round to mounting all front speakers today.
With it being a plasterboard wall and needing noggins for the speakers I decided to attack it from the back in the hallway.
This is what it looks like after putting the boards back...just needs a little filling and painting
This is what its looking like from the front......
and where all cables exit the wall from...
And almost the final result....
Just a little of decorating to do and then to decide on a new unit and av rack.
All in all very pleased how it turned out.
Ray
Old 07-01-2007, 10:38 PM   #13 (permalink)
Also thinking of adding this unit...anyone got one and can comment on build/quality?
Regards
kit, mounting, progressfinally, wall, work
