| Re: Chimney Nightmare!!! Please Advise!
1 is your chimney breast level with the rest of the wall it's on, i assume yes.
2 is the wall your chimney breast is attached to a joining wall to another property if so it may not go straight up it may go left or right to allow for the other chimney.
3 again if the room above has a fire place the chimney may turn left or right.
So either you have to get a light and look up your chimney to see if you can see the change in direction or send some sort of flexible cane or drain rod or fibreglass rods up your chimney to feel what way it bends, you may have drilled some lovely holes into your neighbours chimney.
