Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 18-12-2006, 8:28 PM   #1 (permalink)
madman1178's Avatar
Thanks: Gave 8, Got 10
aluminium stud partition wall??
does anyone know what this is exactly?
i am moving into a new house that has it and i need to mount a plasma on it.
HELP!!!
madman1178 is offline   Reply With Quote
Old 18-12-2006, 8:40 PM   #2 (permalink)
louishm's Avatar
Thanks: Gave 31, Got 54
Re: aluminium stud partition wall??
it is usually thin alluminium box section roughly 2x2 inch, in my opinion nowhere near as strong as 2x2 timber, when first erected without any plasterboard attached it is very flimsy then sturdies up as you attach plasterboard.
personally i wouldn't like to hang a plasma on it, but someone on the forums who is more familiar with it may advise differently.
360 Gamertag:sparky2011. PS3 Gamertag:sparkypaul1.
Visit My Home Theatre
Visit My Re-Build
louishm is offline   Reply With Quote
Old 18-12-2006, 8:48 PM   #3 (permalink)
madman1178's Avatar
Thanks for that mate, one way or another, i am getting a plasma on that wall....if it kills me (or the plasma....i'll make sure its covered in the accidental home insurance)
Would you think if i fix it in lots of places as well as lots straight into the plasterboard it would be secure enough??.....afterall, plasterboards hold up a radiator filled with water???
Old 18-12-2006, 8:58 PM   #4 (permalink)
louishm's Avatar
lol.
give it a go mate, i would rather fix to the ally though rather than the plasterboard,
as for radiators these will be battoned out at some point not fixed just to plasterboard
Visit My Re-Build
Old 18-12-2006, 9:09 PM   #5 (permalink)
madman1178's Avatar
yeah i guess they would be battened....i went to speak to the builder but he was useless, i may as well have asked my wife.
I think i will just cute a small section of plasterboard out (where the cables will go) and assess the wall from the inside.
Nothing is going to stop me wall mounting this plasma. i spent too long planning it!!
thanks for the advice
Old 18-12-2006, 9:16 PM   #6 (permalink)
louishm's Avatar
no probs, let us know how it goes
Visit My Re-Build
Old 18-12-2006, 9:27 PM   #7 (permalink)
madman1178's Avatar
ill be posting pics etc in the "get your plasmas out for the lads" thread....it can only go 2 ways....well or badly.....lets hope its well
Old 19-12-2006, 6:53 PM   #8 (permalink)
Thanks: Gave 4, Got 32
The sutds should be positioned at 600mm centres and will be 50mm wide so if you can find out where the studs are cut out a square of the plasterboard 700mm wide and as high as your bracket then replace with some mdf or other timber and fix your bracket into that!
I wouldnt reccoment using the studs for fixing into as the threads may pull through the studs in time as its only made of tin about 1mm thick!
Any more questions feel free to om me , ive been builing metal stud partitions for 7 years
Jon
Jon Boy is offline   Reply With Quote
aluminium, partition, stud, wall
