Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 18-12-2006, 1:23 PM   #1 (permalink)
Thanks: Gave 29, Got 8
How to make dampened cabinet doors
I have a marble coffee table (supported by 2 legs at either side) under which lies my AV equipment. At the moment it is stacked on each other. I wish to custom make a 2 shelf unit to slide under the table (i.e. the space between the legs). The bottom to house my amp, cd player + sky box, the top, the central speaker. I wish to add a single dampened hinged black/tinted glass door to the lower portion such that on tapping it opens upwards and out. It is the latter I am stuck with - anyone know where to get the latter cut or custom made?
Nabs is offline   Reply With Quote
Old 18-12-2006, 2:06 PM   #2 (permalink)
Re: How to make dampened cabinet doors
Try here http://www.hafele.co.uk/ for hardware. They have the best range of fittings I've seen - unfortunately they are "TRADE ONLY" (you can view the site as a guest) but if you find what you want - they seem to have a couple of auto-opening stays - you may be able to get the item from a good retailer such as Isaac Lord. Hope this helps.
Neil
neilant is offline   Reply With Quote
Old 18-12-2006, 3:06 PM   #3 (permalink)
Thanks: Gave 1, Got 7
get down to ikea and have a look through their modular furniture systems..
I am fairly sure I have seen furniture they offer with this sort of hinge.
Amit
Amit_Desai is offline   Reply With Quote
cabinet, dampened, doors, make
